Help file not comming up!
When i goto open th ehelp fil through the stamp editor or through the actual help.exe it shows a hour glass and then it goes away, there never any help file show up. i looked in my Process Control when you hit CTRL + ALT + DLT and it says Help.exe but there isnt anything showing up! does anybody know how to fix this?
Windows XP Professional
Stamp Editor 2.2.6
-Learn somthing about everything, and Everthing about somthing-
Stamp Editor 2.2.6
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
You should go to·ADD and REMOVE and remove the stamp editor and the Help·and then look in Windows Explorer and remove ALL files that are not
the files that you have saved for your project then reinstall the stamp editor that should work
This has happen to me·before the one thing have done is that all of the project files go into a folder STAMPS·DOWN LOADS so that way if have any problems
with stamp editor then uninstall the program then reinstall it
One thing i have notice is that when you·do alot of changes to a routines in your CODE and want to open the HELP you can not do it
or it·will lock up your computer and you will not know that it has lock up until try log off and it will not log off and shut down
This computer· is a·2005 laptop·with 512·mebites of memory and 1.4·GHz. CPU
·This also happens on a desktop i also have with·1.2 Ghz.CPU and·512 megbites of memory
And one time i got the BLUE SCREAN·Of DEATH that said Out of·Memory Dump this on Windows XP Home
·This happen on the laptop·computer·
Can some one tell if the Stamp Editor run in memory only when running·
·When you close the stamp editor dose the memory clear itself·or dose the memory countinue to hold the program and keep filling
up and when you are out memory that it
It seem that even if you close the editor this dose not help any you are better off to restart your computer every so often this
seem to work better
Now i also use the Stamp editor with Windows 98 SE and the samething seem to happen with it····it is an·older computer
Is there·a problem with editor or is there something else going on that i do not know about
Sam
Post Edited (sam_sam_sam) : 9/15/2006 4:39:01 AM GMT
·Is this only program that you are having on your computer if so then you need to find all files the for the stamp editor and remove them
or restore your computer to date before you had the problems with the stamp editor
Now if you are having other problem with other programs then use this program called spy bot and addware and see if this helps
if not then you may have to use the restore disk that came with your computer and a complete system restore but if you do
this BACK ALL FILE THAT YOU WILL NEED BEFORE YOU DO THIS THEY WILL BE LOST FOR EVER (maybe not)···
And start over········
I have had to do this many times in the past if you can not fix the problems that you are having but ony do this if nothing
else works
Sam
http://support.microsoft.com/kb/902225
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/htmlhelp/html/hwMicrosoftHTMLHelpDownloads.asp·that is the latest help update file to update that dumb thing so thanks for everyones concern i fixed it i think!
) Use MJ's Help Diagnostics to ensure that all the help viewer components are properly installed and registered.
http://helpware.net/downloads/index.htm
(This turned out to be key as the software discovered the ocx file I’d copied wasn’t “registered” and did that for me.)
2) Delete the file "hh.dat", which you should find in this subdirectory:
\Documents and Settings\%username%\Application Data\Microsoft\HTML Help
This file stores information about all the HTML Help files on your system (Favorites, window size and position, etc.), and can cause the files to misbehave if it has somehow been corrupted.
