Pink UDP receiving
Hello,
When my pink receive data with UDP, it saves that data into the Nb_varBM.
But how to readout the value that is located in that var Nb_varBM?
Also, i wrote a html webpage to change some var, and then display these values back to that same webpage.
Is there a way that i can , when i pushed an action button on that webpage, create a kind of delay, so that i am sure that there is enough time to update the changed values into the pink, before it reload the "test" webpage?
No i am using a second webpage "test1" for creating that delay.
Thx
Thx
My Pink is no longer online but this thread should answer your questions.
http://forums.parallax.com/showthread.php?p=568523
Download the test code at the top. Then look further down where I used java script with two web pages to make the action button work every time.
Regards
Tim
