Question about DS18B20 and also KingBright 2 digit 7-segment LED
I'm pretty new to this so if I'm posting in the wrong forum, I apologize. I have two questions I was hoping someone could help me with.
Firstly, I'm working on a little project for monitoring temperatures (various locations within a room). I've seen a few of these out there - but I'm wanting to make my own as an entry project into micro-electronics.
Question 1:
I've got a BS2px24 attached to my Board of Education and right now am simply trying to read a DS18B20 (temp chip).
I've simply copied and pasted the Parallax example program used for OWIN and OWOUT into my dev. environment. (obviously making sure the pins match how I have the Board of Education setup).
When I run the program all I seem to get is 255 for everything - or $FF is you prefer.
The example program says it's meant to work with the DS1820, but can anyone see a reason it wouldn't work with the DS18B20. From reading through both datasheets - it seems they have the same ROM functions.
Question 2:
I'll be using a 2-digit 7-segment LED display from KingBright (it's blue
I've been able to successfully configure a single digit 7-segment (control it from a PBASIC program, etc) but can someone point me to a document that explains how to wire a 2, or 3 digit display on the BOE?
My problem comes from trying to figure out where to get the additional pins on the BOE.
In a more general sense, what do you do when you need to control more than 16 pins? Surely peoples projects have to exceed the board's limit now and again? Again - I'm sure it's trivial - just a fundamental point I don't understand yet.
Thanks Much!
Question 1:
Question 2:
)I've been able to successfully configure a single digit 7-segment (control it from a PBASIC program, etc) but can someone point me to a document that explains how to wire a 2, or 3 digit display on the BOE?
Thanks Much!
·· On the 1-Wire device, please attach (not paste) the code you are running for verification.· As for expanding digits or even I/O, there are many ways to do this.· For the digits you could use a 7-Segment driver chip such as the MAX7219 or the MC14489.· Each of these is controlled by 3 I/O pins and can control 8 displays or 5 displays, respectively.· When expanding I/O, this can be done using shift registers.· There are examples of all these things in our Stamp Works manual, which can be downloaded free as a PDF file from the bottom of the following page.· I hope this helps.· Take care.
http://www.parallax.com/detail.asp?product_id=27220
I've attached the code I'm currently using to try and communicate with the DS18B20 as Project_002.bpx
' {$STAMP BS2px} ' {$PBASIC 2.5} DQ PIN 2 ' 1-Wire buss pin RdROM CON $33 ' read serial number MatchROM CON $55 ' match SN -- for multiple devices SkipROM CON $CC ' ignore SN -- use for one device CvrtTmp CON $44 ' start temperature conversion RdSP CON $BE ' read DS1822 scratchpad tempIn VAR Word ' raw temperature sign VAR tempIn.BIT11 ' 1 = negative temperature tLo VAR tempIn.BYTE0 tHi VAR tempIn.BYTE1 tSign VAR Bit ' saved sign bit tempC VAR Word ' final Celsius temp tempF VAR Word ' final Fahrenheit temp ID VAR Byte(8) PAUSE 500 'Try to send reset and presence pulse OWOUT DQ, 1, [noparse][[/noparse]$33] OWIN DQ, 0, [noparse][[/noparse]STR ID\8] DEBUG "Family Code: ", HEX2 ID(0), "h", CR DEBUG "Ser# ", HEX2 ID(1), HEX2 ID(2), HEX2 ID(3), HEX2 ID(4), HEX2 ID(5), HEX2 ID(6), "h", CR DEBUG "CRC Value: ", HEX2 ID(7), "h", CR PAUSE 5000 Main: DO GOSUB Get_Temperature ' read temperature from DS1822 DEBUG HOME, ' display "DS1822", CR, "------", CR, SDEC tempC, " C ", CR, SDEC tempF, " F ", CR, CR, "tLo: ", IBIN tLo, CR, "tHi: ", DEC tHi, CR, "tSign: ", SDEC tSign, CR, "tempIn: ", SDEC tempIn, CR PAUSE 1000 LOOP END Get_Temperature: OWOUT DQ, 1, [noparse][[/noparse]SkipROM, CvrtTmp] ' send convert temperatrue command DO ' wait on conversion PAUSE 25 ' small loop pad OWIN DQ, 4, [noparse][[/noparse]tempIn] ' check status (bit transfer) DEBUG SDEC tempIn, CR LOOP UNTIL (tempIn) ' 1 when complete OWOUT DQ, 1, [noparse][[/noparse]SkipROM, RdSP] ' read DS1822 scratchpad OWIN DQ, 2, [noparse][[/noparse]tLo, tHi] ' get raw temp data tSign = sign ' save sign bit tempC = tempIn >> 4 ' round to whole degrees tempC.BYTE1 = $FF * tSign ' correct 2's compliment bits tempF = (ABS tempC) * 9 / 5 ' start F conversion IF (tSign) THEN ' finish F conversion tempF = 32 - tempF ' C was negative ELSE tempF = tempF + 32 ' C was positive ENDIF RETURNAdditionally, here is the output I am getting
