assign a word variable to a byte variable in SX/B
Hi all,
just a "stupid" question. I have defined 2 variables, one as byte, one as word, like
v1· var byte
v2· var word
After some calculations, v2 contains a value 0<=v2<=255
Now, I like to assign the content of v2 to v1.
But the line
v1=v2 produces a SX/B error 8 "Invalide Parameter" ....
What am I missing?
Thanks in advance
Gerry
v1· var byte
v2· var word
But the line
What am I missing?
Thanks in advance
Gerry
Use "v1 = v2_LSB".
All word variables automatically create two aliases "name_MSB" and "name_LSB".
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
thanks a bunch !!!!!!!!
Gerry
