Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Rev D Demo schematic — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
Newzed
2,503
2006-09-13 12:54
edited 2006-09-13 16:40
in
Propeller 1
Chris or B
eau
or Paul - why is Pin 9 of the VGA connector tied to 5V on the Rev D schematic?
Pin 9 is NC.
Sid
cgracey
14,323
2006-09-13 16:21
edited 2006-09-13 16:21
Pin 9 is used as a 5V accessory supply (ie 3D shutter glasses). It will be ignored by most every monitor. It's there in case someone wants to use something that requires it. Otherwise, it should be innocuous.
Chip Gracey
Newzed
2,503
2006-09-13 16:30
edited 2006-09-13 16:30
Chip, there is no way to access that.
Pin 9 on the male DB15 VGA connector is missing - just a blank space there.
Sid
Martin Hebel
1,239
2006-09-13 16:40
Sid,
If you had a device that needed the 5V, it would be there.
-Martin
Martin Hebel
Southern Illinois University Carbondale - Electronic Systems Technologies
Personal Links with plenty of BASIC Stamp info
StampPlot - Graphical Data Acquisition and Control
Sign In
Register
to comment.
Chip Gracey
Sid
-Martin
Martin Hebel
