BS2P40 master and 10 Bs2 slaves to be programed
Hello,
My configuration is computer to usb to rs232 to BS2P40 with 10 slaves attached to i/o.
I want to connect the program pin of slaves to seperate i/o pins on the master so slave can have new program sent to it. Is this possible? (each slave will have serin, serout and fc: master will use 30 pins for 10 slaves)
Thanks allanlane5 for the last reply but I couldn't figure it out.
Larryw
Larryw
·· I would recommend studying the tokenizer documentation at the following web page.· You will need to compile the code yourself using the tokenizer in order to get the code into a form suitable for downloading onto the BASIC Stamps from another BASIC Stamp.· It can be done, but it will require a bit of work.· Alternately if you know someone who already has a program written around the Tokenizer Library you could get the code compiled by them and have it stored in DATA statements in another slot on the BS2p40.· I hope this helps.· Take care.
http://www.parallax.com/html_pages/downloads/tokenizer/tokenizer.asp
got it
larryw
