Using an SX proto board in a car's 12 volt system
Basic Jim
Hello all,
I have an application in mind that would draw it's power from·a car's 12 volt system. I was woried that it would strain the proto boards regulator as the 12 volts in car system while running can get up to 14 volts. I checked the specs on the LM2940 and it says it can handle an input voltage of up to 26 volts!
·My question is, if thats so why does the board specify a six to nine volt adapter? A 12 volt adapter·should work fine right?
Just wanted to check with the experts before I go out and fry a board!·
Jim W.
Jim W.
The LM2940 might handle 26 volts, but not at it's maximum current (1 Amp).
That would be (26-5) = 21 Watts of heat !!!
At 9 volts it would be (9-5) = 4 Watts of heat, alot but probably okay with a heatsink.
[noparse][[/noparse]edit] Just checked the datasheet. The TO-220 with no heatsink can only handle a little over 2 watts of heat. With a decent heatsink it can handle about 9 watts of heat. (Those numbers are at 25°C).
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Post Edited (Bean (Hitt Consulting)) : 9/13/2006 1:09:18 AM GMT
Jim W.
Bean.
Thanks again,
Jim W.
Coders' Hangout
A place for programmers to hangout!
http://www.codershangout.com
METROID?
Metroid Classic
I want to tell you now but I need to do a little more research before I blab about it. It's kind of a dumb idea (at least my wife thinks so.) But I think there might be a market for it. Others I’ve shown it to think it's a good idea (or, they are humoring me.) You will probably laugh. (like she did). But, give me a little while to get back to you.
Jim W.
Strong reactions, good or bad, are positive feedback.· If some people love your idea AND some people hate it, it's a winner.
When I got my LPKF PCB milling machine, my wife thought it was the dumbest thing she'd ever seen.
And just because it IS a dumb idea doesn't mean it won't be profitable. Someone made alot of money from the "Pet Rock"... And they still sell the "chia pet". What would your wife had said about each of those ?
Bean.
Hey, I had the idea of putting a small laser gun on a small robot car that had motion sensors. The car would pick up tiny bits of motion from insects (like roaches) and drive to them and shoot them. A tiny, laser shooting, roach killer. That would ROCK.
Coders' Hangout
METROID?
Metroid Classic
No you won't be that OK. I have used he SX48 with 12volts and it runs too warm over a period of time to my liking. Especially if its gonna be buttoned up some place or worse, under the hood. The easiest solution is to offload some of that voltage/power with a three to five 1N4000 series diodes in series with the 12V line, which will drop .7volts per diode. Rememeber that "12v" with regard to a car is a eumphemism for what in reailty is 13-14 volt system. The regulators put ot in the vicinity of 13.8volts. The batteries generally settle down in the low 12v range when the engine has been shut off. And it might not hurt to have a hefty choke in that line to beat down startup transients, as well as an overvoltage protection diode across the input. Automobiles are a very electronics unfriendly environment..
cheers ... brian riley, n1bq, underhill center, vermont
See the K107 Serial LCD Controller at
www.wulfden.org/k107/
Thanks Brian,
The diodes are an excellent idea. I'm not sure how hefty a choke I would need. Maybe I could scavenge one from an old car radio for testing purposes.
Best,
Jim W.
Post Edited (Basic Jim) : 9/14/2006 4:15:44 PM GMT
Greetings from Germany,
G
I just want to expand on that a tad .... not too many years ago, chips came in basically two flavors ... chips and mil-spec chips ... Now they come in more flavors and for the most part the top of the heap, that is, the most demanding specs, is not the military stuff, but ... yup, you guessed it ... chips destined for automotive use!
FWIW ... cheers
Boy! Have I been wasting money.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
That is a fantastic point! I will stock up on those little critters
Best,
Jim W.
Wow, I didnt know that. All this time I thought Mil spec was top of the line. Probably isn't much difference in spec. from military to automotive since both are subject to very extreme enviroments. Military might more robust in EMI surges I would think.
Best,
Jim W.
You said, "I was thinking that you could put a 7809 in front of the SX-48 and have that regulator dump the heat."
That's how I was going to tackle the problem originally. I glad I posted my question. This forum is a fantastic resource!
Best,
Jim W.
Im just wondering for if my own circuits end up in that environment. It seems like a cheap fix to a noisy situation...
· The Zener is like a regulator, once input voltage is greater than Zener voltage, then the difference will be across the limiting resistor.
· Sometimes a Zener is used this way (in parallel with the input)·when the greatest expected input voltage is "just a tad" greater than the Zener voltage [noparse]/noparse][b]V[/b][sub]Z[/sub, intending to then clear a fuse as a result.
· Also, "pre-regulating" with diodes (pl.)·isn't a panacaea, either (i.e. don't get carried away.)
· Post Edit -- If you're interested in an experiment, try using a zener in series with your input to "pre-regulate" with, because it's the same "principle" as using a rectifier diode for voltage drop.
Post Edited (PJ Allen) : 9/19/2006 2:50:26 AM GMT
bongo
G
·For now I will try one of Gunther's P6KEV8 with some 4001 and a choke and that should hopefully get me by.··I have ordered a couple xtra proto boards just in case I'm wrong. If worse comes to worse I could break down and buy a DC-DC converter.
Jim W.
please find attached the schematic for a DC/DC converter. I'm using it in many of my applications, and it works great.
G
Frank
