Propeller Object: HM55B Compass
Beau Schwabe
I will be posting this to the Propeller object library soon.
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
Completely off-topic, but it's been niggling at me -- how do you pronounce your last name!? (shwarbay, shwob, shwabe?)
Cheers,
Simon
Beau:
Boe
Schwabe:
Sh - Wah - Bee
Beau Schwabe
IC Layout Engineer
RoboGeek
"I reject your reality and subsitute my own!"
Adam Savage, Mythbusters
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.startrek.com
Paul Baker
RoboGeek
www.parallax.com
www.expresspcb.com
www.startrek.com
Paul Baker
We use Degrees because it's something we all grew up with, and ppl with med to heavy math know of radians or grads. But, in all actuallity, as long as the unit of measurement is equally distrubutited about the axis, it can be anything. For example: One could define each unit of measure as being most anything, as long as it's understood. Somewhere I saw and played with a formula that defined a circle to 1000 units. I assumed it was degrees. The whole expression was in INT math, was very fast, and confused the smack out of me, until I relized a circle was 1000 units, not 1000 degrees, hence the confusion.
As my Professor stated: "As long as the unit measurment is defined as being equally distrubited around the axis, it is a valid unit of measurment."
Also included was the understanding that you can't change the dynamics of a unit as defined within the same application.
Meaning, once you "define" a unit of measurement, you cant change it.
In this example, theta is the unit of measure, and it's being defined in the application as being a degree.
As Paul indicated, there nothing that says we want it expressed as {Insert your own word} as being (Θ/$2000){enter your connotation}
Ok, it's been a real long time but I think I got that right...
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
