Photo transistor with ADC
Hello again...
I'm just confused about this... How would I be able to connect a transistor with a ADC (I'm still confused and I need help)...
The transistor only consist of an emitter and collector (the sd 1440 serries)...
Is a current liting resistor needed... And is the other input of the ADC grounded..
Thank you...
Provas, Greece...
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
The hellinic (Greek) robots portal: Greekbotics
Many Projects and Schematics by the users·and also robotic news
(Translate using babelfish)
Thank you...
Provas, Greece...
-Rule your Destiny-
Based on your advice, is this going to work...
Look down for·the .rar
-Rule your Destiny-
Post Edited (Provas) : 9/12/2006 7:49:09 PM GMT
