Variable power supply circuit question
I have a bunch of wall adapters that output around 15v-18v DC. I'd like to have a variable power supply that can output 2v-24v at about 1A at least and I found some schematics that uses the LM317 regulator.
The max that the LM317 can regulate to is 12v output though, I was wondering if I could build two of these regulating circuits and put them in series to create a variable 24v power supply? Would this be a good?
If it's a bad idea, should I series the wall adapters first and then run it thru a regulator that can regulate up to 24v?
"Series the wall adapters"?· Bad idea.
Putting the outputs of two 78xx-based circuits:· I have trouble just saying "OK" to this one.
Post Edited (PJ Allen) : 9/9/2006 10:27:58 PM GMT
For this kind of usage, I'd recommend looking at a switching regulator. Their power dissipation doesn't significantly go up with increasing difference between unregulated voltage input and regulated output voltage.
Post Edited (Mike Green) : 9/9/2006 10:37:49 PM GMT
I'll look into the TO-3 package, I don't think I'll need to run anything higher than, say, 18v but I was just wondering if adding the voltages together was a good idea. Can you recommend a switching regulator circuit or IC I should look at?
Thanks guys.
Give them a try.
