60+ Amp Speed Controller
Hey Everyone,
I just finished the speed controller for my heavy-weight (200 lbs)·Stamp controlled Telepresence bot.· Thought you might like to have the pcb, to build one of your own or something.··I etched it onto a 4" X 10" 8oz copper·board, it can handle 60 A continuous, per channel.· Depending on the board you choose, it should be able to handle the following amounts of current per channel...
1oz = 12·A
2oz = 22 A
3oz = 28 A
4oz = 36 A
5oz = 42 A
6oz = 48 A
7oz = 54 A
8oz = 60 A
9oz = 64 A
10oz = 70 A
PWM is provided be two 555 timers controlled by two digital pots.· Then everything is routed through a PCF8547 I/O Expander, this means that the whole thing can be be controlled by a two wire I2C interface, and that 8 of these can be of the same bus.· Oh, and I forgot to mention, the whole thing is isolated by six 4N25 optocouplers.· To open the file you'll need Express PCB (Click here to Download).· Please post any revisions you make to it or errors you find in it.· Also, here's a link to help explain using I2C with the BS2.
Thanks to Everyone who helped me with this,
crgwbr
NerdMaster
For
Life
1oz = 12·A
2oz = 22 A
3oz = 28 A
4oz = 36 A
5oz = 42 A
6oz = 48 A
7oz = 54 A
8oz = 60 A
9oz = 64 A
10oz = 70 A
crgwbr
NerdMaster
For
Life
thanks
Post Edited (HavoKane) : 9/9/2006 1:32:14 PM GMT
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
NerdMaster
For
Life
Post Edited (crgwbr) : 9/11/2006 11:51:49 PM GMT
NerdMaster
For
Life
This controller is a duel H-Bridge driver, therefore it does do direction control.· No, you would only need two of these, as each one can control two motors.· Yes you will need both heatsinks and a fan to cool, even at 0.016 ohms, 50 Amp will genetate a lot of heat (so be careful).· One final thing, as you seem to be a bit of a beguiner, I would recomend just buying somthing like the HB-25.· The programing required to make this thing work is a bit complex (unless your using a BS2-P).
Hope you get your project working,
crgwbr
NerdMaster
For
Life
What is the range of supply voltage for the motors?
How can I find the parts list?
The Parallax controller you speak of is simpler, but at $50 per I would have to buy two per motor to handle the amps if thats possible,·and I would still be stretching it a bit because at stall the motors will draw more. Have you seen anyone using a bs2 use the "open source motor controller" ?· Its rated at hundreds of amps but don't know if its compatible.
I'm not exactly a newbie, I'm just rusty, about 5 years since I worked with the stamp2.· I haven't worked with I2C yet though.
If the BS2P is easier, I'd buy one·to make it work.
Did you make your own PCB?
Nice speed controller what type of heat sink are you using...?
Thanks!
What would that be in HP?
·············· (·60 amps * 9.6 volts = 576 WATTS )
············· u could do a segway·
·········· i got· the new sabretooth from lynxmotion its got regenerative braking
That's about 5 HP. I suspect that is nearer to my Yamaha 100cc scooter.
At 746 watts per HP, its 576/746= 0.768 HP.
PJ's conversion is right as well. ( 60w = 0.08 HP)
Cheers
Tom Sisk
http://www.siskconsult.com
Intially I was trying to compare the wattage to something tangible, but I mess up the math.
576 watts could easily provide heat for a small corner of room.
What size wire do you need for 70 amps?
Seems to 70 amps would be about the same size wire as mains for a small cottage or older home.
The output stage must be quite robust.
This is the whole problem with the low voltage/high amperage path for high power devices. The hardware becomes awkward.
Even airplanes use voltages in the 40 volts range [noparse][[/noparse]trying to stay low to minimize sparks causing fuel leak ignition].
Problems are the "roads" of life,
solutions are only "onramps" to the next problem
············································· "Brad Smith"
Post Edited (Warrlok) : 1/21/2007 4:46:03 PM GMT
