Minimum current/voltage to make the pin input as HIGH.
Hi...
I want to attach the output of an LDR circuit into a pin in Pasic Stamp 2 (after making that particular pin an INPUT).
What is the minimum current and voltage required to make the input HIGH. In another words, what is the minimum voltage that I need to output from the LDR circuit to turn the pin on.
Thanks.
Thanks.
·· Your voltage needs to be above 1.4V to register as a HIGH.· Take care.
Is there a way where I can measure the input impedance..?
Like which pin should I place my ohmeter? And I only measure it after I set the pin as input and measure it whie it is running rite..?
If my understanding is right, high impedance and low current is to protect the Basic Stamp rite..? It will not affect the other output pins as the voltage and current is only use to turn the input pin HIGH.
Post Edited (MrNobody) : 9/7/2006 9:36:49 PM GMT
