RFID Reader - Minimum voltage affects read range
nick412
Just thought it is worth noting that the read range of tags (white plastic cards) seems to be severely affected if anything around the minimum voltage is supplied.
I have a reader that works just fine on the workbench connected to a 5v voltage regulator, however when I put it in a production environment (install it), the reader is connected via solid core telephone cable to a power source 3m away.· The voltage reaching the reader is reduced to around 4.6v (0.1v above the recommended minimum according to the spec sheet) however at 4.6v the read range is only around 1cm.· When connected directly to the power supply, I get around 4-5cm.
If you don't have them already, I'd also add some capacitors right at the reader across the positive/negative rails to help stabilize the incoming power.· Maybe 100 uF to start with?
You could also try lowering the input voltage, so the regulator isn't dumping 7V.· I think around 7.5, even 9V would help lower the heat generated.··If you·use an LDO or·low dropout regulator, you could even use 6V incoming power.
Hope this helps!
-Learn somthing about everything, and Everthing about somthing-
I am getting 5cm or so read range through the box.
That would eliminate quite a bit of the heat at the 7805 because it is proportionate to the voltage that requires reduction.
As Desy2820 mentions, with the 7805, you need about 7.0volts minimum input and being as close as possilbe to that is ideal.
If you used a 2940-5.0 [noparse][[/noparse]low drop out regulator], you could get down to 6.0volts.
Please tell us some range estimates because there have been people stuck with bad results before, but no one consider that low voltage was a contributing factor.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
I consistently got odd readings, such as:
Regulated PSU Input (v) - LM2940CT Output (v)
7.5 - 6.3
9 - 7.1
12 - 8.8
I thought they were faulty, however after adding a 100uf electrolytic capacitor across the output I got the expected result ie 5v on the output. The 7805 regulator works without the capacitors, and I thought they were just for stabilisation, but it seems the 2940 requires an output capacitor for proper operation.
