How do I get the BS2 to write data to my hard drive?
Hello,
I'm interested in having the BS2 write data to my hard drive. I have the BOE attached to my computer with a USB cable. An explanation of what I'm trying to accomplish is as follows:
1) A light sensing circuit is using RCTIME to measure light levels.
2) When RCTIME exceeds a predetermined value, I want the BS2 to record that as a "hit".
3) The BS2 will record the number of hits for one minute.
4) At the end of the first minute, a file on the hard drive is created and the number of hits are written to it.
5) The process continues each minute and the hits per minute are appended to the file.
All help and guidance will be appreciated. Thanks.
Sean
Sean
From THe BASIC Stamp, you need to send:
DEBUG "!LOGD ", DEC value,CR
After LOGD, you can have any string, including a time stamp:
DEBUG "!LOGD (RTIME) ", ..... your data,CR
Prior to sending data, you can change the name of the data log file:
DEBUG "!NAMD mydata.txt",cr
On StampPlot, simply select the com port under "Configuration" and connect.
http://www.stampplot.com
Free for home.educational use.
-Martin
Martin Hebel
Southern Illinois University Carbondale - Electronic Systems Technologies
Personal Links with plenty of BASIC Stamp info
StampPlot - Graphical Data Acquisition and Control
