Designing a Stepper Motor System
Lautarocondor
Hello,
I am trying to design a system that incorporates a stepper motor that drives a “guillotine” like cutter driven by a stepper motor, a simple up and down selector(arrow buttons) to decide cutter depth, and a seven segment display showing the selected position (value between 0-99).
When I select a value, lets say (0), I want the stepper motor to lower the cutter to the fully closed position after the trigger switch is pressed. And then return to the fully open position. And when the value (50) is selected it will close about halfway and then open.
Thanks for your help
Post Edited By Moderator (Chris Savage (Parallax)) : 9/6/2006 5:00:29 AM GMT
- Stephen
If you are cutting something with this device and you have high torque this wont work. Typically a stop sensor (Micro switch) is used to tell the processor when the position is at a known position. Fully open and fully closed sensors could be used, the stamp would count the number of steps from one to the other then divide by 2 to place the blade at center. Scale the number to fit your 0 to 99 close to open after your program measures the full step range.
Think outside the BOX!
