Advice on using 9v battery
T Chap
For longest possible battery using a 9volt non rechargable and an SX28, would you recommend a 7805, or 5v Zener, or somke other method to conserve the battery? If possible, I was planning to put the SX to sleep unless one of two buttons are pressed. The SX sends a byte out via the Parallax 433mhz transmitter, and there's not much else in the box. I was hoping to hoping to get at least three months out of it as the buttons will hardly get used, maybe ten times a day if that. I felt like the killer would be the 7805.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
The advantage of a switching regulator is its higher efficiency compared to linear regulators. I'm using the LM2574 in many of my applications with good results. Although this is a step-down regulator, I found out that it even keeps the output voltage stable at 5V when the input voltage is below 5V but I did not test, how much current can be drawn in this case.
Greetings from Germany,
Günther
G
ps Are you going to use internal osc?
G
I clicked the submit button too fast. Concerning your PS: No, I'm going to use a 4 MHz crystal because the internal osc is not stable enough for the 9600 Baud I want to use for RF communication.
G
This shows the 7805 which be replaced
to be honest, I never tried it, but I will as I could not find any information in the data sheet.
When you are right, this could cause even a sleeping SX draw remarkable current when its outputs pull low signals that are externally pulled up to Vdd, or vice versa when outputs pull high signals that are externally pulled low to Vss. So, it may be a good idea to configure the I/O pins as outputs before sending the SX to sleep (provided, the external components allow for it).
G
17mA SX 28 at 4mhz awake
3mA 433 Tx module asleep
20mA not including unknown regulation variable
I am no math wiz, but is it correct that 1 amphour = 1 hour usage at the working voltage?
1000 mA draw = 1 amp = 1 hour use
100mA draw = 1 hour x 10
20mA draw = 10 hours x 5 = 50 hours
I may be way off here since I really have no clue to the real formulas, but if this is even close, then I am going to need a power switch on the remote Tx which I had hoped not to use.
Use some code like: if But1 = 0 then Tx some byte
Post Edited (originator99) : 9/6/2006 8:48:21 AM GMT
cutting off power completely when no button is down is the best energy-saver I can imagine. The only point is that you may not release the buttons before the SX has done its job sending data via the transmitter. Maybe, a larger elcap across the SX Vdd-Vss pins can hold enough energy to complete the task when a "fast pusher" uses the device. One of these gold-cap parts with very high capacity might do a nice job. I used it many years ago (at pre-SX times) to keep a PIC controller alive for a while.
Concerning your amphour question:
As a rule of thumb, a device with a capacity of one amphour can supply one Ampere for one hour at a voltage within the specified voltage tolerance range. Your calculations are right, to my opinion.
G
This simply follows the first rule of Murphey's Law: "If something can go wrong, it WILL go wrong".
IOW, I'd prefer a "keep-alive" circuit, like a buffer capacitor instead of a blinking LED, consuming additional power.
As a matter of fact, I'm always amazed seeing how many commercially available appliances use an LED as "Battery Low" indicator, adding more surge to the dying batteries .
G
In testing the SX powering up with a switch and then executing led blinking code, the start up delay is virtually unnoticable.
The only reason I thought about the LED was that it gives some feedback as to the battery state. I hate it when somethig isn't working, and I can't tell if it's the battery or not. With an LED, you know if you have a dead battery or not. I have sent remotes flying against a wall for this exact reason!
marshall edgell
Nick
That's a good idea. But remember that in SLEEP mode all RAM is preserved.
When you lose power, you lose all the RAM conents too.
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
Nick
marshall edgell
Nick
marshall
Try the website below. They offer 300/400 Mhz and 900 Mhz FSK modules.·I use them all the time because they are solid performers.
www.linxtechnologies.com·
Nick
Nick
