hb-25 motor controller awsome
when connecting the motor controller in mode 2 do i still need to use two power sources (one for each motor controller) or just connect one to one motor controlller?
I'am using a 12v 4.2 HA lead acid power source is it alright? i think it is for the specs say it can handle up to 35A just need a confirmation.
Thank for all the replies in advance. Have a good one!
·· You don't need two power sources, but you do need power to both modules.· You can connect the power in parallel to both HB-25 Controllers.· I hope this helps.· Take care.
csavage@parallax.com
1 ms as full speed in one direction (lets say Forward)
and 2 ms as full speed in the other direction (Reverse)
so a 1.25 ms pulsewidth would = half speed forward
and a 1.75 ms pulsewidth would be half speed in reverse
This is just an example, if your motor leads are reversed then between 1 and 1.5 would be reverse and between 1.5 and 2 would be forward.
Hope this makes sense.
Charlie
