SX28 with 50m resonator not working
Using the Blitz, the SX programs no problem. The program runs using the following:
OSC4mhz Turbo
4_000_000
But when I program it with OSCHS1 Turbo and 50_000_000 the program will not run after downloading the program sucessfully to the SX. The resonator is at the pins with no caps.
Any ideas on whats going on?
Post Edited (originator99) : 9/5/2006 6:08:47 AM GMT
OSC4mhz Turbo
4_000_000
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
Post Edited (originator99) : 9/5/2006 4:59:49 PM GMT
If this is the same low-power circuit you are talking about in other threads, then I would recommend a 4MHz resonator. If you can be by with the internal 4MHz that's great. But I wouldn't recommend it.
Bean.
Circuit is only the resonator across osc pins with center to GND.
Steps:
1. Program SX with Blitz using OSCHS1, 2, OSCXT1, 2 and both 50m and 4mhz res, with respective FREQ set for each
2. Remove Blitz and insert resonator after programming
3. Reset power
The program doesn't run with the Blitz plugged in using external osc modes (with no resonator in place)
I have tried 2 SX chips on two different breadboards that run fine in internal, resonator is close as possible
The chip programs so the pins must be connected on the breadboards.
5vdc on osc2
1.5vdc on osc1
No obvious clock on either pin in ac or dc modes
Bean.
http://www.parallax.com/dl/docs/prod/boards/SX28ProtoBDRevBschematic.pdf
John J. Couture
San Diego Miramar College
· In my experience if MCLR is not connected the SX will not program either.
Bean.
Bean, I discovered something. The only test I have been using for the resonators is the code posted above which is a serial Rx program. I have another Sx doing the Tx, and the code works fine on the internal 4mhz. It does not work using any variation of resonators and directives.
I just did a test with a program that does nothing but blink an led, and the program runs fine on the 4mhz resonator, so now my problem really is that the serial Rx doesn't work when using the resonator. The Tx chip is using internal osc. I'll test having the resontaor on both Tx and Rx tomorrow.
1. Write a simple LED-blinker program, connect an LED with a 470 Ohm resistor in series between the SX pin used for LED-control and ground, and disconnect the resonator in case there is one installed.
2. Make sure that the code contains a FREQ 50_000_000 directive, launch the debugger from the SX-Key IDE, and hit the RUN button.
When the LED blinks, you can be sure that the hardware is fine, and your test program as well.
3. Re-program the SX from the IDE using the "Run/Program" option to get rid of the debug code inside the SX.
4. Select "Run/Clock" from the IDE, and set the clock frequency to 50 MHz.
When the LED blinks again, you are still in good shape.
5. Quit the SX-Key IDE, power down the system, remove the SX-Key, and insert or connect the 50 MHz resonator.
6. Power up the system again.
When the LED does not blink, the resonator might be defective. If you have an oscope with sufficient bandwidth available, you might check the signal at the SX OSC1 pin. You should see a 50 MHz sine wave when the clock is working.
Greetings from Germany,
G
·· It seems in all cases you're not using a resonator on the Send SX.· Perhaps they're out of sync, so to speak.· I would make sure you have a 4 MHz resonator on both sides so they're at the same speed in terms of serial communication.· I hope this helps.· Take care.
The transmitting chip may be sending at a rate that is higher or lower than 9600 baud. When you use a 4 MHz resonator on the RX chip, what are you using to clock the TX chip? The clocks on the two chips must be consistent with each other.
Dave
The moral of the story is to have resonators on both chips and save yourself a lot of frustration. Just because it works with no resonator on either side, does not mean that you can stick a resonator only on the Rx side only and expect the same results. All is fine! I can't wait for the 433 modules to be restocked.
