BASIC Stamp II and C#
GreenGiant83
I connected two servo's together to make a two axis pointer.· I want to be able to control the positions of each of the servo's from a c# program I am writing.· Right now my stamp is basically:
DO
DEBUGIN DEC xpulse,·DEC ypulse
PULSOUT 14, xpulse
PULSOUT 15, ypulse
PAUSE 20
DEBUG 0 'Finish command
LOOP
In my C# program uses the MS Comm control.· I have a timer that sends the x and y pulse widths and then wait for the finish command.· The problem is that there is to much of a delay between the commands, and that makes the movement choppy.· Is there anyway to use c# to write to the chips memory that the stamp could read from with out blocking control while waiting for the debugin command?
DO
PULSOUT 14, xpulse
PULSOUT 15, ypulse
PAUSE 20
LOOP
csavage@parallax.com
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
InVal2 VAR WORD
DO
GOSUB GetPulse ' Include the 'pause' in GetPulse
PULSOUT 14, xpulse
PULSOUT 15, ypulse
LOOP
GetPulse:
SEROUT 16, 16468, [noparse][[/noparse]"."] ' Prompt PC to send the data
SERIN 16, 16468, 20, Timeout, [noparse][[/noparse]DEC InVal1, DEC InVal2]
IF InVal1 <> 0 THEN xpulse = InVal1
IF InVal2 <> 0 THEN xpulse = InVal2
PAUSE 20 ' When here, got data fast, so need a pause
TIMEOUT: ' When here, timed out, so we've already spent our 20 mSec
RETURN
·· If you look in the BASIC Stamp Manual or the Editor Help File under the SERIN/SEROUT command you will see that the baud rates are not specified as numbers like 2400 or 9600.· Instead you would define a constant and use that.· It could be something like N9600, but that value is derived from the parameters listed for these commands.· For 9600 baud true (8, N, 1) you would use 84, however since the programming port is inverted that number becomes 16468.· I hope this helps.· Take care.
At 9600 baud, each bit takes 1/9600, or 104 uSec. Now, if you're sending 8N1 (8 data bits, No parity, 1 stop bit) then each byte takes 10 bit periods (start bit, 8 data bits, stop bit) so that's 1.04 mSec per byte sent. So no, if you set the timeout to 1 mSec you'll never get any data. It will ALWAYS time out.
Now, you realize, that the BS2 will not take any data unless it is 'pending' (waiting) in the SERIN command BEFORE the data starts. This is because the BS2 does no buffering of serial data. So there's a timing issue here.
You also realize, that in the 'pause' part, the BS2 is doing NOTHING else except pausing. So, if the BS2 is doing 'nothing' anyway, it might as well be doing nothing while 'pended' in the SERIN statement.
Yes, in the the "SERIN 16" statement, the '16' is a 'pseudo-pin', that tells the BS2 to 'listen' to the programming port. This means P0 through P15 are free for use by your program.
If you really want it to work efficiently, you'll program the PC side to send its data as quickly after it recieves the "." as possible. This will 'release' the 'pended' SERIN statement as quickly as possible.
I assume I can·send values of up to 65536 into InVal1 and InVal2, is that true?· From my program in c# what do I need to send out?· Before with the debugin statement I was sending for example "1000\r" a brief pause followed by "500\r".· With this SERIN being one call would I output "1000\r500\r"?· I realize that this a string value which is like char 49 char 48 char 48 char 48 char 13, which makes me wonder if I need to output the data in a different fashion.· I apoligize if this post is somewhat cryptic, I am very new to the hardware scene.
A variable defined as a BYTE can have values from 0-255. A variable defined as a WORD can have values from 0-65535.
Bruce Bates
<!--StartFragment -->
·· I still hgihly recommend sending the data in BINARY format.· Using the DEC formatters will still require you to send the ASCII digits of those values, requiring up to 12 bytes instead of the 4 it would take to send any value in BINARY.· You can send the values LOWBYTE/HIGHBYTE and put them directly into the WORD variables on the receiving side.
SERIN 16, 16468, 20, Timeout, [noparse][[/noparse]InVal1, InVal2]
Now, since you have TWO "DEC" parameters, the SERIN won't return until the time-out passes, or it gets two parameters. So you don't HAVE to send them in the same string, but you could if you wanted to. I believe if it gets the first value, then times-out, that the first parameter will have a value, while the second parameter will be set to zero.
Note also, at 9600 baud each character takes about 1 mSec -- so sending "1000\r500\r" would take 9 mSec -- which should work fine. "10000\r10000\r" would be 12 mSec -- still fine, assuming your PC waits for the "." signal before it sends.
Now, you COULD tell the SERIN to recieve 'raw bytes'.
SERIN 16, 16864, [noparse][[/noparse]MyVal1.Highbyte, MyVal1.LowByte, MyVal2.HighByte, MyVal2.LowByte]
This would take less time to be transmitted, but you'd have to 'split' the values on the C# side. It's doable, though. Harder to debug, as you can't read the strings by eye any more.
Note anything sent to the BS2 WILL be 'echoed' back by the BS2 hardware, so make sure on the C# side you filter that stuff out.
P.S. There should be a check to ensure that the int value passed does not exceed 65536.
Bytes[noparse][[/noparse]1] = (byte) (Val / 256) -- assuming "/" is integer division.
Is there a 'right shift' operator in C#?
