Method of encryption for RFID>Propeller
If using the Propeller to receive a serial number from an FRID device where there is a minute chance someone could have a sniffing device near the devices: what type of system could be implemented to encrypt and decrypt the signal to avoid unauthorized use?
However, if you are making the silicon, then it stands to reason that you could transmit a public key to the tag, and the tag will return an encrypted signal that only you have the decrypt key to...
Um... why do you need the tag's id to be private?
www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=77
