DevBoard Output behavior
Not sure if this is really an issue or if I'm doing something wrong. I wanted to get this grps' thoughts
I got my dev board (and a whole bunch of sensor toys w/ that, including the propkit - don't tell my wife).
If you run the below code (note #2 is commented out) on devboard;
········ #1 - lights up LED @ p16 and #2 - LED @ p17·work as expected.
········· However, uncomment #2 line ahead and re run it.
················ I see #1 work as expected,
················ I see #2 work as expectd (p18/19 light up) and
················ when the execution hits #3,
························· I see the LED @ pin 17 light up and at the same time 18/19 stay lit up
what am I missing.
thanks, ALIBE
Pub Main
· Toggle(16,3_000_000,10)· '· #1
· ' Toggle(19,4_000_000,5)·· '· #2
· Toggle(17,1_000_000,15) '· #3
Pub Toggle(Pin, Delay, Count)·················
· DirA[noparse][[/noparse]Pin]~~
· Repeat Count
··· !OutA[noparse][[/noparse]Pin]
··· WaitCnt(Delay + cnt)
Your #2 and #3 have odd numbers for <count>. This will leave the state of the pin high when started from a low state. An even number will leave the pin in the low or off state.
thanks for the catch.
It helps is I paid some attention - does'nt it [noparse]:)[/noparse]
