Controlling analog dials via stamps
I would like to contol some analog gauges like automotive gauges for tach, speed, oil temp, gas gauge, etc from some form of basic stamp· whether its the BS1, bs2, sx, or propeller.· I would ultimately like to make the project be able to hook up to a pc via usb so I can control it via software to make the external gauges for a virtual car I am making.· It would be great if I can make it Human Interface Design (HID) complient, but I dont know how more complex or even if this would fall into a HID design since it's more of an 'output'·then an input. (I will have to read up on that)·
Any suggestions or directions on this would be very handy!· Has anybody done something like this?
You could do a few things to mimic this. You could look in to controlling a digital Potentiometer with the stamp...and set up a voltage divider using the digital pot and another reference resistor.
OR, you might look in to Pulse width modulation. Install PBasic editor and go to the help menu and look up Pulseout....essentially, you could pulse out to a transistor that switches 5volts on and off.....if you switch the 5volts so that's it's on for half the time and off for the other half (known as 50% duty cycle) you could invariably have 2.5volts.
Guys, please jump in if I'm simplifying this too much or have missed something.
Op-amps might be another method....but I'll let someone else chime in on that one!
Cheers
Steve
You will need to pick your meters and see what it takes to get them to move. It will probably need more current than a Stamp pin can provide.
Since this will be a virtual car, you may want to pick a meter you like and that responds well and then just change the face markings to what you want them to say.
I did something like that in a project once where they wanted two meters that would display heat and cold. I only had a couple of 1mA analog meters so I made up a graphic for the faces and used resistors to adjust the needle range.
Hope this helps.
Lee
Dale Bartel
Portland Or
If it's option 1 (existing guages), then the input for them will depend on the guage. Some (like mentioned above) take a 0-5V signal, others take a 0-12V signal; and some are voltage-driven, but some are current driven; and a few (like speed and tach) are pulse-rate driven. If you are going to use a PWM signal; I might suggest using something like a ULN2803 to drive them; as that will protect your MCU from any inductive issues (some meters have coils in them).
If it's option 2 (DIY guages), and you don't want to go digital; you could use some RC servos, and just mount needles on them; they are easy to drive, and interface directly to your MCU. Google "microcontroller RC servo", there's lots of info. Third link down when I just did it was this:
http://www.geocities.com/BourbonStreet/3220/servobasics.html
which has a good explanation of the control signal.
I'm playing with the same idea at present, but large guages, 600mm or 2 foot in Diameter. I've played with Steppers but servos seem to be the answer.
Circuit Cellar No 189 - April 2006 has a very interesting article on a·remote, radio controlled (Zigbee) guage. It displays the NASDAQ. I suggest you get the magazine and look the article up. Attached is a Photo from the article.
General knowledge question - Who knows what·NASDAQ stands for? Don't google it now. We South Africans·use the JSE, Honkong the Hangsen and Germany the DAX
Kind regards from Africa where even the fall of the NASDAQ doesn't upset us.
John Bond
I have thought of using servos before but thought they would have·2 problems for my purposes:
1: they are noisy
2: They are not very quick responding - so they don't look like a 'gauge' in movement
I also like the idea of the previous post to find a guage I like and then change the graphics to suit my needs.· There is one guage I might have problems with though as it's an old 'smith' style dual guage.
·I supose I could have 2 servos in that spot work.· I just need fast-acting and lightweight servos I guess.
Post Edited (OakGraphics) : 9/6/2006 7:09:07 AM GMT
If you can lay your hands on CorelDraw, Guages are a piece of cake...
I produced a quick example of a dial but unfortunately·our internet service won't let me send it.
Kind regards
John B
