Ir beacon
IR BEACON
I am working on a project that has a boe bot reading a beacon from another stationary BOE with an IR LED. Basically I have broken up the diagram on page 243 of Robotics with the BOE-BOT so that there is only one transmitting IR LED and it is attached to another BOE (the detection part still stays the same). Is there any way to extend the range of the beacons transmission or the detectors ability to get an accurate reading over distance.
Also the BOE-BOT seems to home in on my laptop and my plasma TV more often then the beacon. Is thee a way to stop the errors. I thought of putting a bit of data in the beacons IR but would that still allow for homing to a beacon?
beacon code
ir CON 1
red CON 0
'red_led VAR BYTE
'ir_led VAR BYTE
DO
FREQOUT IR, 1050, 38500 'ir beacon on
FREQOUT red, 100, 38500 'red LED for the humans
LOOP
homing code is fast ir roaming. reversed.
irDetectLeft VAR BIT ' Variable Declarations
irDetectRight VAR BIT
pulseLeft VAR WORD
pulseRight VAR WORD
FREQOUT 2, 20, 3000 ' Signal program start/reset.
DO ' Main Routine
' Check IR Detectors
irDetectLeft = IN1
irDetectRight = IN0
' Decide how to navigate.
IF (irDetectLeft = 0) AND (irDetectRight = 0) THEN
FREQOUT 2, 200, 500 ' Signal program start/reset.
pulseLeft = 650
pulseRight = 850
HIGH 3
HIGH 4
FREQOUT 2, 200, 5500
ELSEIF (irDetectRight = 0) THEN
pulseLeft = 850
pulseRight = 850
FREQOUT 2, 200, 200
HIGH 4
ELSEIF (irDetectLeft = 0) THEN
pulseLeft = 650
pulseRight = 650
FREQOUT 2, 200, 300
HIGH 3
ELSE
ENDIF
PULSOUT 15,pulseLeft ' Apply the pulse.
PULSOUT 14,pulseRight
LOW 3
LOW 4
LOOP ' Repeat main routine
beacon code
ir CON 1
red CON 0
'red_led VAR BYTE
'ir_led VAR BYTE
DO
LOOP
pulseLeft VAR WORD
pulseRight VAR WORD
DO ' Main Routine
irDetectLeft = IN1
irDetectRight = IN0
pulseLeft = 650
pulseRight = 850
HIGH 3
HIGH 4
pulseLeft = 850
pulseRight = 850
FREQOUT 2, 200, 200
HIGH 4
pulseLeft = 650
pulseRight = 650
FREQOUT 2, 200, 300
HIGH 3
ELSE
ENDIF
LOW 3
LOW 4
do
if(FoundBeacon = True) then
BeaconCount = BeaconCount +1
endif
if(FoundBeacon = False AND BeconCount <> 0) THEN
BeaconCount = 0
goto Roam
endif
loop until(BeaconCount = 200)
it homes in and makes sure that the signal its receiving is constant, if not then it starts roaming again until next time
-Learn somthing about everything, and Everthing about somthing-
And yes, a pattern of:
FOR I = 1 to 10
FREQOUT IRPin, 1, 38500
PAUSE 1
NEXT
should be read by the BOE-BOT as a bunch of 1 mSec pulses -- very different from the TV remote or laptop signal.
Allan is of course correct. Is it CURRENT with an LED which will give you greater output, not VOLTAGE. The voltage for an LED is realtively fixed.
Bruce Bates
<!--StartFragment -->
I looked at some setups like this and a lot of them use a much higher frequency LED frequency and detector frequency (56khz vs 38.5) which puts it in a higher range than regular remotes which may help interference. I would also think the detection range is greater, but I don't know enough about the opto-physics of IR -- others may know more. I saw a beacon like the one above in use on two robots and they homed in on each other from across a fluoroescently-lit room.
I think I could get the parts but would not have an idea of how to program the PIC
Also came across this. www.robotmaker.co.uk/IRCF/IRCF_benefits_Features.htm
it looks like more of an IR navagation device then beacon reader (but the text says it can read a beacon).
can you send a FREQOUT of 56khz on a BS2. I will have to try that when I get hoome tonight.
Post Edited (Special_K) : 9/1/2006 7:11:04 PM GMT
You can also make your own freq. generator for IR and the like with a 555 (single) or 556 (double) timer IC -- which are like 50 cents.
Steve
To mark something like a home base, or a recharge station, or a goal.
if i could get a data bit encoded in the beacon it could serve to distinguish different docks.
Of course there would have to be something like a MOSfet between the Stamp and all those LEDs. I imagine you could have 20 or 50 if you wanted to.
You coulds·easily use a 555 to generate a pulse and tune it to the right frequency. That would be a lot cheaper than a Stamp if this beacon in merely a drone.·
You could also get away from the 38500KHZ as the band is crowded with remove controls and IrDA.· I believe that an IR photodiode and having the BS Pulse in tuned to something different and not harmonic would clear up a rather messy situation.· If you want high stability use a TTL oscillator [noparse][[/noparse]like 4 Mhz] and divide the pulse down with an IC to something usefull.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 9/5/2006 4:03:01 PM GMT
also I swapped out the resistor from a 220, to a 100, then to a 10 I think it will not hurt anything am I right??
I did some tests with Paper an visible LEDs and the LED with the 10 resistor shows through 2 more sheets of standard 20 LBS press 92 brightness paper. I think this will translate into a few more feet.
also if I do the same to the IR detectors (go from a 220 to a 10) will that increase their range also????
Post Edited (Special_K) : 9/5/2006 5:00:46 PM GMT
And it's the number of sheets that's important. For instance, you say it shown through two more -- what is the TOTAL number of sheets it showed through? Three? 12?
And NO!· You cannot increase the "sensitivity" of a detector by lowering the value of the protection resistor.· You're increasing the intensity of the LIGHT output by the LED by increasing the current through it.· There IS NO equivalent way to increase the sensitivity of the detector -- it is what it is.
Post Edited (allanlane5) : 9/5/2006 5:04:05 PM GMT
' {$STAMP BS2} ' {$PBASIC 2.5} ir1 CON 0 ir2 CON 1 red CON 2 'red_led VAR BYTE 'ir_led VAR BYTE I VAR BYTE DO FREQOUT IR1, 10, 56500 PAUSE 20 FREQOUT IR2, 10, 56500 PAUSE 20 FREQOUT red, 10, 37500 PAUSE 20 LOOP.
the detector sees the IR LEDS.. is it really working are the leds pulsing at 56500 or have I pushed the freqout past 37500 and it is still only pulsing at 37500.
problem is it looks like it is only getting half the number of hits at 56500.
Post Edited (Special_K) : 9/5/2006 7:10:39 PM GMT
Actually the maximum value for the frequency parameter is 32767. There is something unexpected (but useful) that happens after that point, and it was described in a thread about 30-60 days ago. Unfortunately that's all I remember about it - sorry.
Bruce Bates
ir1 con 0
ir2 con 1
red·con 2
Write instead:
ir1 PIN 1
ir2 PIN 2
red PIN 3
Sid
Sid Weaver
Do you have a Stamp Tester yet?
Freakout (freqout) trick
Beau Schwabe
IC Layout Engineer
Which is probably NOT what you want for a beacon. Just set it to 38,000 (or whatever they recommend) for the best detectability.
If I remember (since I did not write anything down) the light from a standard LED with 220 resistor can get through 4- 5 sheet depending on the weight. The LED with a 100 resistor can get through 9 and the LED with the 10 ohm resistor 11 sheets.
I did this just to check the apparent brightness since after looking at one bright led the next LEDs brightness was indistinguishable to my eye.
Test done in a room with standard florescent lighting and daylight.
SID, thanks for the pin suggestion.
So it looks like I have maxed out my LEDs with 10 ohm resistor and a freqout of 37500. This gives me some good distance
Post Edited (Special_K) : 9/7/2006 2:55:56 AM GMT
Will a BOE power something like this?
cgi.ebay.com/20x-5mm-infrared-IR-LED-LEDs-Night-vision-goggle-camera_W0QQitemZ250027478015QQihZ015QQcategoryZ26207QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item250027478015
