Need some math help
I have found a site that has a schmitt trigger calculator and it shows the formula (Attached file)
Link to site: http://hyperphysics.phy-astr.gsu.edu/HBASE/electronic/schmitt.html#c3
Problem is, I never learned how to read the math symbols they are using so I am having a hard time converting this information to an excell spreadsheet format.
Can anyone help me understand it. I really do hat the fact that I usually gloss over the math examples in electronics books because I don't understand what is written on the page. I never got a chance to go to college.
I have tried
V2 = (((R1 * R2 * R3) / R2) * VREF) + (((R1 * R2 * R3) / R3) * VCC)
V2 = (((100 * 200 * 300) / 200) * 5) + (((100 * 200 * 300) / 300) * 5)
With R1=100, R2=200, R3=300, VCC=5 then V2 should = 2.272727 and I get 250,000
So I don't get what R1||R2||R3 is
From the math symbol table here: http://whatis.techtarget.com/definition/0,,sid9_gci803019,00.html
It looks like || means "The Product of" and from my 8th grade math education I think that means multiply
Why do they have to be so greek to me?
Think outside the BOX!
Post Edited (metron9) : 8/31/2006 4:17:45 AM GMT
I have tried
To calculate the equivalent parallel-wired resistance,
1 / Req = (1 / R1 ) + ( 1 / R2 ) + ( 1 / R3 )··
So, for example, given parallel-wired resistors, R1=10, R2=20, R3= 50 ohms, you want to find·the equivalent resistance, Req, ·provided by a single resistor, as:
1 / Req· = 1/10 + 1/20 + 1/50
········ = 0.10 + 0.05 + 0.02
········ = 0.17 ohms
So, R123 = Req·= 1 / 0.17· = 5.88 ohms
The ballpark check on the·answer for parallel equivalent resistance,·Req, should be less than the smallest resistor (among the parallel-wired ones), and 5.88 is smaller than 10, so the answer is in the ballpark direction.
(BTW, " || " is the math "absolute value" symbol; in the table you cited, the symbol you mistook for "||" and which does represent "the product" is the symbol Pi in that table. The table symbol Pi was a bit illegible.)
·PAR
There must be some handbooks of symbols, electronic and math so i will look at the bookstore.
