SERIN With SX
When you run SERIN with the SX Chip, does it just grab what is currently on the line, or does it wait for the start bit?
ie...If I have a neutral 5V on the pin, will it automatically read "FF" and move on with the program, or will it Halt the program, and 'wait' for a start bit and data?
thanks
Shaun
thanks
Shaun
SERIN will wait for the input to go to the IDLE state before clocking in any bits. So if the line is held in the ACTIVE state, it will wait.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
