Using a pin as a variable...
Howdy...
Is it possible to use a pin as a variable ?
Right now I have eight pins defined as following:
These pins represent chip·1 and chip 2 of the same type chip.
And then two subroutines using these pins.
Now every time I add a subroutine, I have to add two of them, one for chip 1 and one for chip 2.
What I want to do is to to use one routine and pass a variable 1 or 2 depending on which chip I want to access.
For two chips it might be easier to just do an if statement and then select either SHIFTOUT command. However I probably want to add more chips and I wonder if it is possible to do something like this.
I tried this·and the defined pins will not chage.
Is this possible ???
Any other suggestions ???
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
CanRX1 PIN RC.7 input 'CAN Receive to MCP2515 PIN 15 SO CanTX1 PIN RC.6 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs1 PIN RC.5 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk1 PIN RC.4 output 'CAN Clock to MCP2515 PIN 13 SCK CanRX2 PIN RB.7 input 'CAN Receive to MCP2515 PIN 15 SO CanTX2 PIN RB.6 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs2 PIN RB.5 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk2 PIN RB.4 output 'CAN Clock to MCP2515 PIN 13 SCK
resetCan1: LOW PINcs1 SHIFTOUT CANTX1, PINclk1, MSBFIRST, $C0 'Send a RESET command HIGH PINcs1 return resetCan2: LOW PINcs2 SHIFTOUT CANTX2, PINclk2, MSBFIRST, $C0 'Send a RESET command HIGH PINcs2 return
CanRX1 PIN RC.7 input 'CAN Receive to MCP2515 PIN 15 SO CanTX1 PIN RC.6 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs1 PIN RC.5 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk1 PIN RC.4 output 'CAN Clock to MCP2515 PIN 13 SCK CanRX2 PIN RC.3 input 'CAN Receive to MCP2515 PIN 15 SO CanTX2 PIN RC.2 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs2 PIN RC.1 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk2 PIN RC.0 output 'CAN Clock to MCP2515 PIN 13 SCK CanRX3 PIN RB.7 input 'CAN Receive to MCP2515 PIN 15 SO CanTX3 PIN RB.6 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs3 PIN RB.5 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk3 PIN RB.4 output 'CAN Clock to MCP2515 PIN 13 SCK CanRX4 PIN RB.3 input 'CAN Receive to MCP2515 PIN 15 SO CanTX4 PIN RB.2 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs4 PIN RB.1 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk4 PIN RB.0 output 'CAN Clock to MCP2515 PIN 13 SCK CanRX PIN RB.3 input 'CAN Receive to MCP2515 PIN 15 SO CanTX PIN RB.2 output 'CAN Transmit to MCP2515 PIN 14 SI PINcs PIN RB.1 output 'CAN Chip Select to MCP2515 PIN 16 CS PINclk PIN RB.0 output 'CAN Clock to MCP2515 PIN 13 SCK . . . resetCan: chip = __PARAM1 if chip = 1 then PINcs = PINcs1 CANTX = CANTX1 PINclk = PINclk1 elseif chip = 2 then PINcs = PINcs2 CANTX = CANTX2 PINclk = PINclk2 elseif chip = 3 then PINcs = PINcs3 CANTX = CANTX3 PINclk = PINclk3 elseif chip = 4 then PINcs = PINcs4 CANTX = CANTX4 PINclk = PINclk4 endif LOW PINcs SHIFTOUT CANTX, PINclk, MSBFIRST, $C0 'Send a RESET command HIGH PINcs return
Experience level:
/Bamse
Pins are constants. They cannot be change at runtime. You'll need routines for each set of pins.
Bean.
There are only two guaranteed ways to become weathy.
Spend less than you make.
Make more than you spend.
That is pretty much what I figured...
I just need a way of figuring out how to do something similar otherwise all my subroutines will eat up all the programming space...
I have 5 subroutines per chip, making it a total of 10 subroutines today, if I added two more chips, that would br 20 subroutines...
Well, using two SX chips would probably work as well, one SX chip per two MCP2515...
Experience level:
/Bamse
· If you're only using the SHIFTIN and SHIFTOUT commands, it wouldn't be too hard to make specialized versions that WOULD allow different pins to be used. If you don't need high speed, you could probably write them in SX/B too.
· I would use a method of numbering the pins from RA.0 to RC.7 with number from 0 to 23 (I know that RA.3-RA.7 don't exist, but it makes the code easier to pretend they do). Then do something like:
· I would just make routines to set a pin number high and low. Then just call them as needed in your higher level subroutines (like shiftout).
· Let me know if you need for info, but I think that will work for ya.
Bean.
Post Edited (Bean (Hitt Consulting)) : 8/30/2006 1:21:42 PM GMT
