help reading data from MaX110/MAX11 !!
i am starting working with ADC and Basic Stamp and i hope someone could help me with this.
This is what i have but i dont know exactly if this is ok or not, because i dont receive data from data in,
if you look at the code, i do a shiftout and then a shiftin (which i dont know if its correct) and what i am reatriving is just the same data that was sent by the shiftout
so, i dont know what i am missing, timing.. enable/disable cs.
Variables
ADCin VAR Word 'ADC reading
Constants
cs CON 2 'enable or disable A to D converter
serDo CON 1 'serial data out
serDin CON 0 'serial data in
serclk CON 3 'serial Clock
HIGH cs 'disable
main:
DEBUG CLS
LOW cs 'enable
GOSUB chkADC
GOSUB prnt
GOTO main
chkADC:
SHIFTOUT serdin, serclk, MSBFIRST,[noparse][[/noparse]%1000110010000000\16] 'send the channel data
SHIFTIN serDo, serclk, MSBPOST,[noparse][[/noparse]ADCin\16] 'the reading 'the reading
HIGH CS
RETURN
Prnt:
DEBUG "ADCBits Chanel= "
DEBUG DEC adcin,CR
PAUSE 1000
RETURN
Variables
Constants
HIGH cs 'disable
main:
DEBUG CLS
LOW cs 'enable
GOSUB chkADC
GOSUB prnt
GOTO main
chkADC:
HIGH CS
RETURN
Prnt:
DEBUG DEC adcin,CR
PAUSE 1000
RETURN
