Parallel Lcd & Serial Lcd.
Alireza
This is my first post, trying to connect a parallel lcd to a bs2p, First I noticed that it’s a lot easier to work with a serial lcd than a parallel. But is there any kind of adaptor to make my parallel lcd to a serial lcd or I should throw away my parallel lcd and buy a serial lcd.
I am really new to this world, I have had a hard time to understand the diagram of connecting a parallel lcd to a bs2, I don’t understand what that variable resistor? is.
I wish there was a picture or step by step guide for connecting a parallel lcd to BOE.
By the way what’s the difference between these two (parallel and serial)?
Thank you
‘Alireza
Thank you
‘Alireza
Punch up the EDE IC's on the following web site, and look for the LCD Screen Control IC's:
http://www.elabinc.com/
That will give you your interface chip.
Bruce Bates
<!--StartFragment -->
If you already have a parallel display it will be cheaper for you to just buy an add on board.
Another good source for economical LCD displays is Sparkfun. They have a serial LCD adapter also, in addition to a nice variety of colors of LCDs.
http://www.sparkfun.com/commerce/categories.php
PIC-an-LCD (Seems to have been replaced at BG Micro by the K107)
http://www.phanderson.com/lcd106/lcd107.html
And of course, if you do end up needing a Serial LCD, we have some inexpensive Serial Displays such as the following...I hope this helps.· Take care.
http://www.parallax.com/detail.asp?product_id=27976
csavage@parallax.com
