doing project now
im doing a project on smart navigational for blind people. and im using ultrasonic sensors for this purpose. i'll be using 6 ultrasonic sensors, 4 motors and 1 audio for the I/O. I was told that basic stamp is the easiest interface that i can use in my project. i've read the spec for the basic stamp. but the technician at the lab told me that it has 15 I/O and 4 are only for motors. is that true? theres a bit conflict now. im still in the documentation of my project but i want to do some experiments right away, so that what im doing is in the right path. HELP PLS...
Life is like a bar of chocolate... you'll never know what you're gonna get - Forest Gump
-Martin
Martin Hebel
Southern Illinois University Carbondale - Electronic Systems Technologies
Personal Links with plenty of BASIC Stamp info
StampPlot - Graphical Data Acquisition and Control
That does assume you're using "Servo Motors" -- which can be controlled with a single I/O pin.
Better even than accepting what we're saying here, you should download a copy of the "PBASIC Syntax and Reference Manual" for yourself, so you can dispell any other faulty information you may be told about the PBASIC Stamp. One of the real beauties of ALL Parallax products is they they're FULLY and CAREFULLY documented, and that information is freely available for download. Here is where you can obtain a copy of that PBASIC manual:
http://www.parallax.com/html_pages/downloads/basicstamps/documentation_basic_stamp.asp
Bruce Bates
<!--StartFragment -->
http://my.farnell.com/jsp/endecaSearch/partDetail.jsp?sku=1006205
i know that the input for the sensor is 20V and i need to use an amplifier to make it work. the question is that can i connect the ultarsonic sensor directly to the basic stamp or i need to use an interface circuitry so that the ultrasonic can receive and transmit waves?? if yes... could you recommend me a website that can interface the sensor with the basic stamp. i have search many sites but it turns out blank... i really need someone help here and fast. another question is that the ultrasonic module parallax, do they have a circuit before the output can be read by the basic stamp??
because i could not see the module's picture clearly. HELP.................
I'm afraid all you've purchased is an ultrasonic transducer and nothing more. There is NONE of the necessary support circuity which will be needed for ultrasonic echo-location or ranging.
The Parallax PING))) Ultrasonic Sensor is COMPLETE and contains all of the necessary support circuitry, as well as providing an appropriate interface for a PBASIC Stamp, or any other micro-controller or computer.
Bruce Bates
