I/O Question
When a set port RA as outputs i am getting a high output before i actually set the pins to high.
if i have two LED connected to RA.0 and Ra.1 they would light up when i set the port as output. i don't want that. i want to turn the LED on only when i set the output as high.
whant to set RA pins as output, but i don't want i don't want a 0 or a 1 to be outputed at the time i set the RA· pins as output.
thanks!
thanks!
