PINK - Command needed to read the Nb_varBM variable
Forum,
I've done some testing and verified that the Nb_varBM is used as the data variable for both sending a UDP message out and receiving a UDP message.
The PINK manual shows command !NBOWBM to write to variable Nb_varBM but it does not show the command needed to read the contents of variable Nb_varBM. I've tried a number of guesses but none have worked for me. I've searched the forum but haven't found the answer.
If I've missed it in the documentation please point me in the right direction or if you have read the contents of variable Nb_varBM could you let me know what command you used?
Many thanks in advance!
Frank Schorr
Frank Schorr
(the 0 is·the zero, not a capital O).
regards peter
Post Edited (Peter Verkaik) : 8/28/2006 5:13:33 AM GMT
Frank
