help im scared
master of life and legos robots
Time Required to Complete Initial Programming
Boe-Bot SumoBot The Toddler QuadCrawler HexCrawler
40 hours 40 hours 60 hours 20 hours 20 hours
This is what it says on the parallax web site is it true that i takes 40 hours to program the boe bot that a long time did they mean 40 mins. that is a long time i dont have that much time to write programs i just boght the boe bot for $61 with tax and two day shipping that cheap right im new to boe bots and parallax i am a mindstorm fan
go to my web site to see some of my advanced lego mindstorm robots and soon to be boe bots\
ok ethan steckmann
ok ethan steckmann
This is a total number for completing all the projects. Once you work through the boebot projects be prepared to spend additional time exploring the pbasic programming language. You can get a head start while you wait by downloading one of the many available resources from the downloads section.
Here is alink to the boebot student manual to help you get started.
http://www.parallax.com/dl/docs/books/edu/Roboticsv2_2.pdf
Post Edited (KB3JJG) : 8/27/2006 6:19:08 PM GMT
The Parallax Stamps in Class courses are designed to be an educational experience, so they give you an estimated amount of time to carefully read, work through, and understand the material.
Once you've built the Boe-Bot, you could download or copy/paste the funal program and have the robot running in minutes -- but the only thing you will have learned is how to download or copy/paste a program.
Some of the courses are written by people with advanced degrees, or teaching college engineering courses. So you can learn a lot about electronics, microcontrollers, and robotics. But unless your brain has an "instant download" feature that nobody else has, it will require some effort & some time.
Where is the link to your website?
This is not about typing. It is about learning and exploring.
Above all, the most important thing is to read and really understand the text.
Then, the next important thing is to do each task as a learning experience and try to identify what you have learned.
Finally, try to be creative.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Ron Giuntini
San Francisco
