Sending a varible to a serial LCD
I have been having trouble sending a varible to the parallax serial LCD.· I am using the SX48 proto board with the internal 4mhz.· I am able to send a string but I can't send a number variable correctly.· It comes out as random characters such as a series of backslashes.· Any help?
· You need to convert the variable into ASCII characters.
· Here is a routine to convert a Word variable into 5 ASCII digits.
Word_To_Digits SUB 2 Word_To_Digits: tempW = __WPARAM12 char = "0" DO WHILE tempW >= 10000 INC char tempW = tempW - 10000 LOOP SendChar char char = "0" DO WHILE tempW >= 1000 INC char tempW = tempW - 1000 LOOP SendChar char char = "0" DO WHILE tempW >= 100 INC char tempW = tempW - 100 LOOP SendChar char char = "0" DO WHILE tempW >= 10 INC char tempW = tempW - 10 LOOP SendChar char char = "0" + tempW_LSB SendChar char RETURNBean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Post Edited (Bean (Hitt Consulting)) : 8/27/2006 6:52:45 PM GMT
byte_To_Digits:
tempW = __PARAM1
char = "0"
INC char
tempW = tempW - 100
LOOP
LCD_OUT char
char = "0"
INC char
tempW = tempW - 10
LOOP
LCD_OUT char
char = "0" + tempW
LCD_OUT char
RETURN
