Can one merely use Lead Solder with RoHS product?
LoopyByteloose
I have soldered a lot of dis-similar metals over the years - copper, brass, iron, tin, nickel, silver, and so on.
One can even use aluminum if you can manage to break through the oxide coating long enough to get the solder to bond.
So it seems to me that I should be able to use lead solder on RoHS devices - like SMDs, sockets and components.
After all I am a hobbyist and not exporting to Europe.
Is there any reason to consider a special flux or special preparation?
As it is, I have quite a few older parts that I just want to mix as needed.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
Equipped with his 5 senses, man explores the world around and calls his adventure science
-Edwin Hubble
AND that the water soluble flux is optimal [noparse][[/noparse]I guess the clean up is easy].
I can live with that.
I still wonder about the tiny,tiny components - like resistors and capacitors.
I have been thinking that having all these 'tacked' in place with some kind of glue would make the soldering much easier.
Epoxy and super glue seem a bit of over-kill. Maybe very unforgiving of rework.
A wax of some kind might work and dissolve in solvent for clean up.
Has anyone seen a commercial product?
For now I am leaning toward tweezers, toothpicks as applicators, and super glue.
You'll probably have better luck dispensing solder paste (90% solder balls and 10% aqueous or RMA/RA flux) and then reflow soldering in a converted toaster oven such as www.sparkfun.com/commerce/present.php?p=Reflow%20Toaster
Ho ho ho , just a newbie
