Water souble flux
Newzed
Does anyone know where I can get water soluble paste flux.· I've searched everywhere I can think of but can't find it.
Sid
Sid Weaver
Do you have a Stamp Tester yet?
Sid
Sid Weaver
https://webvia.techni-tool.com/VIA/index.jsp
Good ol' Techni-Tool!
I would be interested in the water-soluble flux being included in the solder core, but that seems unavailble.
Currenty, I am cleaning rosin flux from boards with 3M General Purpose Adhesive Cleaner.
I am sure that it is not doing my liver any good and may even cause liver cancer.
I was using alcohol, but found out that alcohol is actually corrosive to metals.
It immediate begins to oxidize solder.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
· The flux/rosin is in the solder for a reason.· "Cleaning" it off is a cosmetic consideration, but counter-productive at that: it's·the equivalent of·leeching.· The rosin protects the solder on the shelf and [noparse][[/noparse]watch this, kidz]·with proper technique, on the board, too (if you're going to heat/cook the joint till the flux turns black, then forget it.)
· The only validation for removing it is to coat the assembly afterward.· Some RF/HF·circuits·can be·adversely affected by rosin (when it gets betwixt and between·IC and transistor pins.)
For "No-Clean" flux I would agree.
However RA (rosin active) and RMA (rosin mildly active) I think corrosion can occur if the flux is left on.
I'm not sure about water soluble flux, I can't think bathing your circuit in water would do it any good either ?
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Sid
It's not paste?· Well, look around there, they probably have it.
Good grief man, don't use the anhydrous alcohol for CLEANING, try it on the rocks with a twist of lime <HIC>
Bruce Bates
<!--StartFragment -->
Bruce, the alcohol is 91 percent isopropyl - you can't drink the stuff!!
Sid
488CH450 -- Kester Flux Pen
Designed to dispense the right amount of liquid.· For rework and soldering touch-up.· Formula 2331ZX Water soluble flux.· Lead Free Approved.
$3.85 ea
Oh well.·
You can lead a horse to water...
Sid
I was at Ace Hardware and they have water-soluble paste flux in, like,·margarine containers.· Maybe it's not suitable for electronics work.
Cleaning PCBs in water is OK, so long as they aren't energized --·you just need to bake them out, like you're doing, or leave them out for a few days (use distilled water.)
I'll keep looking around.
Sid
