A command I need
Hello all,
I am using a basic stamp 2 with pbasic 2.5.
I need to figure out a way to essentlaly say when a certain input of pulses reaches a certain number it will turn a certain pin high. AFter a short Delay that pin will go back low.
The program still needs to count pulses even while bringing pins high and low.
THen it needs to do the whole thing over again.
A basic idea I had was if there was a "when" command I could just say when pulsein = 45 or so bring pin 1 high.
Anybody think that might work.
Has anybody got any better ideas?
Thanks in Advance!
Thanks in Advance!
PULSIN pulse, 1, time 'counts pulses from the optoisolater and stores it in var time
IF time = 45 'measures the counted pulses, change in accordance with the opto disk used
THEN HIGH 1 'brings pin one high
PAUSE 20 'pause for 20ms
LOW 1 'bring pin 1 low
I'm not sure exactly what you're looking for, but you might look at DO ... UNTIL, or DO ... WHILE.
Bruce Bates
Post Edited (Bruce Bates) : 8/24/2006 3:35:23 AM GMT
'measuring' a pulse width.· So the attached does the 'measuring'.
It looks like you want to count pulses not measure their width(time on or time off)
There is a when command in the context you describe only its called IF THEN construct
Assuming your pulsein is a variable that your code keeps track of. >>>this is not the pulsin command<<<
IF pulsein = 45 THEN bring pin 1 high
so a program loop might look like this (in psudo code, psudo code= non executable code for demonstration of program flow)
pulsein = varaible
inputpin = pin you are measuring pulse on
buttonflag = variable
pulsein=0
main program loop
if pulsein=45 ; did we count 45 pulses yet?
pin1=high ; yes so make pin1 high
pin1counter=50 ;A counter to measure the time pin1 stays on
reset pulsein to 0 ;reset the counter
endif
;code continues here
>>>counters to count pulses and keep track of time pin1 is on<<<
if buttonflag=0
if inputpin=1
pulsein=pulsein+1 ;here is where we count pulses
buttonflag=1 ;turn on a flag so we know button is pressed down
endif
endif
if inputpin=0
buttonflag=0 ;reset button flag
endif
if pin1counter>0
pin1counter=pin1counter-1
if pin1counter=0
pin1=LOW ;reset pin1 to low after counter runs out
endif
endif
goto mainloop
so your program runs in a loop checking variuos flags and pin conditions and setting and resetting pins and flags depending on the condition of all the various flags and pins.
You have to take into account how fast the loop executes, to have timw for other processing you need to define your input source of the pulses, I assumed a button press by a person, without the buttonpress flag the counter would go to 45 as soon as you press the button because the BS2 is running 2000 lines of code per second. Read some GAME programming using BASIC for most any computer to learn about the type of loop structure above. The other way is to use interrupts to count but that is not available in the basic stamp 2 model.
I wish you luck in your programming future.
Think outside the BOX!
