Boe-Bot Programming Question
Hello,
·Does anyone have a program written for the Boe-Bot that solves a maze using the two wire wiskers·and then make a transition to a line follower using IR sensors? I would like to use only the parts supplied in the Boe-Bot kit, but will purchase anything needed to complete the task.
·Thank you
·Thank you
·· While we don't have any code already written to do this, if you had a BS2pe you could use multiple program slots for different programs and activate them based on the state of a given sensor at reset time, or even the push of a button.· At the same time, for your maze-solving you'd had a lot of EEPROM space to store a "map" of the maze.· I hope this helps.· On the other hand, depending on the complexity of each program you may be able to put functionality of both into one program.· Take care.
csavage@parallax.com
·I was just hoping that it had been done before to save me the programming time.
·Professor of Physics
