SX/B and array
TransistorToaster
Hello,
I'm looking for an effcient way to handle a byte array in SX/B. It is not for a lookup table. The goal is to have easily compilable high level code.
Can I replace the below code
array1 var byte(16)
ptr1 var byte
x var byte
i var byte
ptr1 = array1
ptr1=ptr1+i
get ptr1, x
with something like array1 ?
Frank
array1 var byte(16)
ptr1 var byte
x var byte
i var byte
ptr1 = array1
ptr1=ptr1+i
get ptr1, x
Frank
Use the virtual array __RAM() like so:
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
Nice to hear from you again. Is there anything with built in indexing?
N.B. The previous post seems to have lost the index...
>with something like array1(i) ?
Frank
I don't follow what you mean by "Is there anything with built in indexing?".
What exactly is it you want to do ?
Array names are just constants into the __RAM() array. So array1(5) basically gets translated into __RAM(array1+5) by the compiler.
Bean.
I've been doing assembly for 10+ years. I agree that the declaration array1 var byte(16) assigns the address of the first element of array1 and that __RAM(array1+5) is absolute addressing, with, as you said, just constants.
I am not looking for indirect addressing , which is pretty much the first piece of code I wrote. (OK, we don't use that term for non-assembly languages)
I'd like to do in SX Basic array1( i), where i is a variable.
In RISC assembly with no absolute indexed support, it should be quite ugly and look like
mov fsr, #i ;2cc pseudo-instruction
mov fsr, ind ;2cc pseudo-instruction
add fsr, #array ;result in IND = array1(i).
Frank
In SX/B you CAN do:
Now if i is a WORD, you'll need to use:
Other than that, keep beating me over the head until you get what you want. I'm a little lost (but it's early, and I haven't had my Mt. Dew yet).
Bean.
