SD card
I am trying to connect my Stamp with a SD card reader Writer.· I want to beable to connect the SD card to hyperterminal to test the syntax of the commands instead of trying to reprogram every time. Dose anybody have a schematic or suggestions on an interface?
·· Without knowing which SD Card Reader you are referring to there would be little information anyone could offer.· This wouldn't happen to be a USB Device, would it?· If so you won't be able to access it from a BASIC Stamp.
csavage@parallax.com
There is a good deal more to it than meets the eye. You may want to check out this excellent SD card reader/writer interface from one of the fellows here on the Stamp List:
www.sddatalogger.com
Bruce Bates
<!--StartFragment -->
To hook that device directly to a computer you need a ttl level convertor, they can be bought starting at $20 or so for a serial to serial version.·Parallax has·a USB to ttl level serial adaptor for $29 http://www.parallax.com/detail.asp?product_id=28024
As far as a schematic for such a device, google and you will find a bunch for serial to serial. You might reconsider this option as you will find many uses for this cable when attaching components directly to a pc, having a quality cable will eliminate any frusterations due to cable/equip failure down the road.
