SX/B I2C Command — Parallax Forums
SX/B I2C Command
RsadeikaRsadeika Posts: 3,877
edited 2006-08-21 18:11 in General Discussion
Any chance of seeing, in the very near future, an enhancement to the I2C command, in particular a slave ID function. Would be nice to have the ability to address different slaves on the I2C bus.
Also, any chance of being able to assign the sda and scl pins. I have a PCB that has the sda and scl pins hard wired oposite to what the I2C command allows.
Ray
Post Edited (Rsadeika) : 8/20/2006 8:26:46 PM GMT
  • BeanBean Posts: 8,129
    edited 2006-08-21 16:57
    Ray,
    I'm don't follow about an I2C "Slave ID" function ? You can access different slave devices as long as their addresses and/or device ID's are different. The I2C devices I've used don't have a unique ID (as 1-wire devices do).
    The I2C commands are meant to mimic the BS2p, so only one pin is specified. You could take the compiled code and change the pins then put it into your program as an assembly block (ASM...ENDASM).
    Bean.
    Cheap 4-digit LED display with driver IC·www.hc4led.com
    "You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
  • RsadeikaRsadeika Posts: 3,877
    edited 2006-08-21 17:56
    Below is the PBASIC command description for I2CIN. It has a SlaveID requirement, my interpretation is that if you have two eeproms on the same line, you specify which eeprom you want to address, by using the eeprom ID.
    I have the I2C_UART demo board, on the board I have two hardwired I2C lines. On one of the I2C lines there is an eeprom and a two pin connector ( I2C bus). If I had another I2C device on the two pin connector, I would need a SlaveID to get to that device, correct? Now, if I was really ambtious and added more connectors and added more I2C devices, how do I get to them.
    Ray
    I2CIN Pin, SlaveID, Address {\LowAddress}, [noparse][[/noparse]InputData]
    p
    Function
    2
    Receive data from a device using the I C protocol.
    • Pin is a variable/constant/expression (0 or 8) that specifies which
    2
    I/O pins to use. I C devices require two I/O pins to communicate.
    The Pin argument serves a double purpose; specifying the first pin
    (for connection to the chip's SDA pin) and, indirectly, the other
    required pin (for connection to the chip's SCL pin). See explanation
    below. Both I/O pins will be toggled between output and input
    mode during the I2CIN command and both will be set to input
    mode by the end of the I2CIN command.
    • SlaveID is a variable/constant/expression (0 – 255) indicating the
    2
    unique ID of the I C chip.
    • Address is a variable/constant/expression (0 – 255) indicating the
    2
    desired address within the I C chip to receive data from. The
    Address argument may be used with the optional LowAddress
    argument to indicate a word-sized address value.
    • LowAddress is a variable/constant/expression (0 – 255) indicating
    2
    the low-byte of the word-sized address within the I C chip to receive
    data from. This argument must be used along with the Address
    argument.
    • InputData is a list of variables and modifiers that tells I2CIN what to
    do with incoming data. I2CIN can store data in a variable or array,
    interpret numeric text (decimal, binary, or hex) and store the
    corresponding value in a variable, wait for a fixed or variable
    sequence of bytes, or ignore a specified number of bytes. These
    actions can be combined in any order in the InputData list.
    Ray,
    There is no need for a special "slave ID function" with I2C.
    The "slave ID" is simply a value you send with the normal I2CSEND command.
    There is nothing special about how you send it.
    See the example program under any of the I2C commands in the help file.
    Bean.
