Reset a Servo?
Circuit Smasher
If you issue the following PBASIC command, the servo will turn to it's mid point:
PULSOUT rx_tiltServo, 750
Is it possible to somehow move the servo to some position and make it use that as it's mid point?
The reason I am asking is because I built a pan/tilt mechanism, but the servo that tilts up and down does not have it's mid point where I wanted it.· I can take the whole thing apart and fix it, but if there is a way to handle this in code or adjust the servo, I would like to do that instead.· Thanks!
