Problem with SERIN command
First· I use Basic Stamp 2SX. I connected P0 to my computer RX (pin 2 in DB9 female connector)· and P1 to my computer TX (pin 3 in DB9 female connector). And wired pin 5 in DB9 female to basic stamp GND.
after that
I writing a little program to send "Hello World" to computer (using Hyper Terminal). It's work fine.
the problem is·I want to send some character from my computer but nothing happend.
this is my code ( i wrote with led blinking)
I don't know how to make SERIN work. I will correct hardware or something else or not?
sorry for my bad english.
ps. I try every way·I try such as making VB and C try to sending one charactor but It's not working. The result is the same SEROUT is work but SERIN is not.
after that
'{$STAMP BS2sx}
'{$PORT COM1}
tmpOUTL var Byte
dummyByte var Byte
ch var Byte
DIRH = %11111111
OUTH = %00000001
baudmode con 17405
ch = "-"
tmpOUTL = OUTH
Main :
tmpOUTL = tmpOUTL << 1
if tmpOUTL = 0 THEN Refresh
BUTTON 7,1,255,250,dummyByte,1,SENDRS
SERIN 0,baudmode,1000,LED_OUT,[noparse][[/noparse]ch]
LED_OUT:
OUTH = tmpOUTL
goto Main
Refresh :
tmpOUTL = 1
GOTO LED_OUT
SENDRS:
OUTH = %11111111
SEROUT 1,baudmode,10,[noparse][[/noparse]"Basic Stamp Said : Hello World > ",ch,10,13]
Goto Main
I can see at least one path through your program which may eventuate in no read (SERIN) being done by the Stamp. May I suggest that you cut the program down tothe bare essentials, and then go from there:
DEBUG "Program Initiating"
READ:
Serin IPin, Baudmode, Timeout, [noparse][[/noparse]databyte]
SEROUT OPin, Baudmode, [noparse][[/noparse]"Stamp received ", databyte]
END
Timeout:
DEBUG "Timeout occurred"
GOTO READ
END
Or something like that.
Bruce Bates
<!--StartFragment -->
ummmmm My programming skill need a lot of improve.
I use a simple code as you said.
'{$STAMP BS2sx} '{$PORT COM1} dbyte var byte baudmode con 17405 DIRH = 255 OUTH = 1 READport : SERIN 0,baudmode,2000,TimeOUT,[noparse][[/noparse]dbyte] SEROUT 1,baudmode,[noparse][[/noparse]"Receive ",dbyte] GOTO READport TimeOUT: OUTH = OUTH + 1 GOTO ReadportO.K. and a little help can you explain my previous code is not usable please.
Thank you, Very much.
