433MHz RF Modules and USB2SER - HELP!
I am trying to use a USB2SER connected to a 27981 reciever and 27980 transmitter to talk to a BOE that is also equipped with a 27981 and 27890. I can't seem to make it work and I'm not sure how the Tx/RX modules wouldn't be confused anyway (i.e.·a transmission from the·USB2SER transmitter might be recieved by both the USB2SER and BOE recievers).
My configuration is as follows:
1. BOE Vdd connected to 5V inputs of all transmitters and receivers
2. BOE Vss connected to GND on all transmitters and receivers
3. BOE pin 0 connected to reciever A
4. BOE pin 1 connected to transmitter A
5. USB2SER RX connected to reciever B
6. USB2SER TX connected to transmitter B
These are all direct connects and there are no other wires or equipment wired in.
I programmed the BS2 with the following code:
x VAR Word
y VAR Word
DO
·· PULSOUT 1, 1200
·· SEROUT 1, 16468, [noparse][[/noparse]"!", x.HIGHBYTE, x.LOWBYTE, y. HIGHBYTE, y.LOWBYTE]
·· x=x+1
·· y=y+1
·· DEBUG ? x
·· PAUSE 10
LOOP
I then used the StampDAQ program connected to COM 4 (USB2SER) to attempt to recieve data. I notice in the debug window that I see x=1 and then nothing else. Also the StampDAQ shows no input. Am I doing something wrong?
My end goal is to send a signal from the PC, recieve it with the BOE, then transmit a response, and finally recieve that response on the PC and display the value. Can anyone help with this?
x VAR Word
y VAR Word
DO
·· PULSOUT 1, 1200
·· x=x+1
·· y=y+1
·· DEBUG ? x
·· PAUSE 10
LOOP
·· Perhaps you should confirm that you are continually receiving data outside of StampDAQ, perhas using the Stamp Editor DEBUG Window.· That would be a good place to start.
csavage@parallax.com
if (serialPort1.IsOpen)
textBox2.Text = serialPort1.ReadExisting();
I saw the following output in the recieve text box: [noparse][[/noparse][noparse][[/noparse]???[noparse][[/noparse]?
It only showed up after pressing the reset button on the basic stamp, so I think I am getting a signal. I'm just not sure what the signal means. After continual recieves, I get no response unless I reset the basic stamp. Each time I reset, I get another response. The basic stamp program is as follows:
'{$STAMP BS2}
'{$PBASIC 2.0}
'{$PORT COM1}
x VAR Word
y VAR Word
DO
· PULSOUT 1, 1200
· SEROUT 1, 16468, [noparse][[/noparse]"!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE]
· x=x+1
· y=y+1
· PAUSE 10
· DEBUG· ? x
LOOP
It almost seems like it doesn't get the DO loop.
Sending the string "!1234" from Com4
'{$STAMP BS2}
'{$PBASIC 2.5}
'{$PORT COM1}
x VAR Word
y VAR Word
PAUSE 100
DO
SERIN 2, 16468, [noparse][[/noparse]WAIT("8"), x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE]
DEBUG ? x
DEBUG ? y
LOOP
I loaded the following into the basic stamp:
'{$STAMP BS2}
'{$PBASIC 2.5}
'{$PORT COM1}
x VAR Byte
DO
SERIN 2, 16468, [noparse][[/noparse]x]
DEBUG ASC ? x
LOOP
I then opened hyperterm and typed 1. The debug screen shows the following:
x="E" where·E is a character that I cannot type into this message box.
Typing 2 returns the same character as 1. Typing 3 returns just ". Typing lower case a returns the same as 1 and 2.
Any ideas as to what is going on?
