Vibra Mass Tab Help
Hi All,
Does anyone have experience working with the Vibra Mass Tab? I'm using 4 of them as vibration sensors hooked to a BS2 through an A/D converter. Besides the zener and a resistor, is it really necessary an OP amp? Any recommendations for a different ADC. (4 channels, 8 or 12 bit). I'm using an MCP3208 that i don't feel comfortable working with because I have not seen anyone using it, and I'm not getting very accurate data.
The idea of the project is to read the sensors and send midi to Max/Msp.
Martin
Martin
Now that I see what you're using, what gave you the impression that you could develop a usable, or meaningful analog voltage from this sensor? The Parallax documentation certainly doesn't imply that.
What you may want to use is a guitar pick-up or something like that. From that kind of sensor, there MAY be a meaninful and usable analog output. THEN you can run it through an ADC and perhaps produce some meaningful results.
Bruce Bates
<!--StartFragment -->
Martin
I use the CEP-1110 as a pickup.
Think outside the BOX!
