math operator % — Parallax Forums
math operator %
Peter VerkaikPeter Verkaik Posts: 3,956
edited 2006-08-19 11:23 in General Discussion
I was trying out some math operators with word variables.
+ (add), - (sub), * (mul), / (div), | (or), ^ (xor), & (and) all compile correctly.
The % (mod) opens a dos window with a listing up to the statement where % is used.
ramX var word
ramY var word
result var word
ramX = result % ramY
gives this strange behaviour.
Either the % is not working or it not the mod function.
Any comment on this?
Edit: just noticed that // is the mod operator.
Then what does the % do, it gives a listing but not an error message.
regards peter
Post Edited (Peter Verkaik) : 8/19/2006 10:54:08 AM GMT
  • BeanBean Posts: 8,129
    Peter,
    Looks like you found a bug. It's causing the compiler to hang. I'll look into fixing it.
    The % is used to prefix a binary value. That is what is confusing the compiler.
    Bean.
    Cheap 4-digit LED display with driver IC·www.hc4led.com
    "You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
    Post Edited (Bean (Hitt Consulting)) : 8/19/2006 11:34:25 AM GMT
