SX/B vs. BS2SX Differences
Yendor
I'm a little confused on where the SX28 and SX/B fits in with the BS2SX or if it does at all -·even after reviewiing the Parallax information.·
First of all, can anyone·confirm the following for me?
The BS2SX (.BSX extension) and the SX/B (.SXB extension) are two complely different animals and speak different languages, correct?
The SX/B is not really compatible with any other basic stamp language (BS2, BS2E, BS2SX, BS2P, BS2PE), correct?
And are there any similarities between the two micros (SX28 BS2SX)?
Any links/forums/threads that help with explaining the·coding differences?· I guess the best is to download the BS2SX documentation to intrepret·the commands.
I apologize if this repeats·prior threads.
·· SX/B is a free compiler for the SX Microcontroller.· The BS2sx is a BASIC Stamp and already has a BASIC Interpreter in its firmware and cannot use SX/B code.· BASIC Stamps are only programmable in PBASIC using the BASIC Stamp Editor.· SX/B is for the SX line of microcontrollers, of which the SX28 just happens to be the core controller used as the interpreter on the BS2sx.· The SX48 is used in the BS2p models of BASIC Stamp.· I hope this helps.· Take care.
csavage@parallax.com
I meant to compare BS2X vx. the SX28, but I see the relation now.
So in a since, the SX28 using the SX/B is more efficient & faster than BS2SX using PBASIC, and the same as the SX48 using the SX/B is more efficient and faster than BS2P using PBASIC.
I'm surprised that the basic code is so different between the SX/B and PBASIC. Can you help me understand why Parallax took a different direction w/ the SX/B if they use the same micro? Power/Efficiency/Speed?
Thanks!
Actually SX/B isn't that different from PBASIC. I mean the commands are pretty close. Now the structure of the program is different, but again that is because SX/B is compiled.
I should add too that SX/B is a one pass compiler. That forces certain things to be declared before there used.
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
