wiring a cvs camera to a boe-bot
i dont know if anyone has ever done this but if some can help me do this that would be great.
I want to put a camera on the boe-bot and i have a cvs camera and i took it apart and here is the pin out tell me if you need any more info.
Im Using the BoE board and a basic stamp 2 micro controller
Thanks.
Heres the pin out.
EDIT:
I found this.
Here is the pinout for the CVS one time use camcorder. Pin 1 starts at the end where J5 is printed on the PCB.
1 no connection
2 ground
3 no connection
4 Battery + (probably used to verify the battery level when recycling)
5 no connection
6 USB +5V
7 ground
8 USB Data +
9 USB Data -
10 ground
Pins 6 - 9 is the only pins needed to connect to a USB port.
Edit:
Another one with descritions:
Post Edited (Meatstick) : 8/17/2006 8:57:36 PM GMT
Thanks.
Heres the pin out.
EDIT:
I found this.
1 no connection
2 ground
3 no connection
5 no connection
6 USB +5V
7 ground
8 USB Data +
9 USB Data -
10 ground
Edit:
Not sure what you what to do but the CVS cam in not the easiest thing to work with.
