I got A big NASTY SHOCK from my boebot
I was testing the ir head lights when the right 1 did not work. i tryed to remove the ir recepter and when i touched the top of it i got shock that seemed like about 49 amps or so but im not sure about the amp thing.
My Father managed to disconnect the power from the board but wut should i do.
oh and p.s there was a small smell that smeeled kinda smokish
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Dave
Dave Andreae
Tech Support
Is your computer setup properly grounded to the outlet?
I.E. you haven't cut or knocked out the ground terminal on your power strip so that you can use the older 2-prong outlet have you?
Are you on a boat? (implied by your name)
Regardless of what your answer is, it may be wise to invest less than $10 at your local hardware store to purchase an outlet tester.
This sounds like there may be an issue with the electrical outlet, your computer and boebot are plugged into.
Beau Schwabe
IC Layout Engineer
Were you running it off of an AC adaptor? If not what kind of batteries? Was the serial/USB cable plugged in when this occured?
http://www.homedepot.com/prel80/HDUS/EN_US/jsearch/product.jsp?pn=100062242
For $8 you can purchase a GFCI Circuit Tester to determine if the outlet is
wired properly or not.· If there is a problem, call an electrition.
Beau Schwabe
IC Layout Engineer
-Learn somthing about everything, and Everthing about somthing-
Touching something you think could be live could end up deadly. It does not take much to stop your heart.
Check it with a meter first.
One of the best features of the BasicStamp is that is usually operates at a low voltage and in isolation from 120VAC so that it is extremely safe.· It is also very unlikely to generate sparks that are hot enough to start a fire.·
You·obviously had some kind of electrical event.· You·could feel it and smell it.· If you were operating the Board of Education on batteries, there is no questionable power supply involve.· [noparse][[/noparse]It is possible to have a defective wall wart that might by-pass the transformer's isolation].
So, the only other place for this to come from would seem to be·your computer programing cable -- the·RS-232 cable or USB cable.· Everyone takes safety pretty seriously.· So the question is how would you get this kind of failure and will it occur again.
You can get a 'static electricity' shock, but you wouldn't usually smell it.·
You might have touched the BoE when a lightning strike was occuring somewhere in the distance.· It is possible.· There are some pretty funny stories of what happens to a cowboy that is peeing on a fence post when lightning strikes the same fence wire some 50 miles away.
The real issue is to verify that the BoE is working and safe to operate.· If it works without being hooked up to your computer, you probably can feel safe to touch it.· Look for signs of damage - burn marks.· Also, did you have this board on a metal surface, in a pile of bare wires,·or a piece of tin foil?· At times, we short circuit the board because we are in a messy work area.
If your computer is now acting normal, you might reconsider what the weather was like when you were working.· It is never a good idea to work on electronics in lightning storms [noparse][[/noparse]you might experience something unpleasant -·like the cowboy].· In all honesty, I do continue to work through lightning storms. But I have quite a bit of surge protection in place.
If you can identify damage to your computer, that is obviously the pathway and you should make sure it is safe to work with.· While the BasicStamp is inherently very safe, you can connect it to something that isn't.· The usual serial connections are designed to be user safe, but you may need to have a repair shop check yours out.· If you computer is not properly grounded, get it grounded.· That is an important safety system that should always be used.
Any other kind of connections to telephones, to house current, and transmission lines really take good knowledge of how to protect yourself from shock and your home from fire.· After all, it is electrical power.· If you are trying to DIY these connections, it is at your own peril.
Also, my own experience around boats and saltwater is that electricity becomes even a greater hazard.· Saltwater is highly conductive and can create uns=usal forms of damage just from a splash of it.· With an otherwise mild shock, having one foot in seawater might just send you to your grave.
"If you want more fiber, eat the package.· Not enough?· Eat the manual."········
Post Edited (Kramer) : 8/20/2006 7:15:52 PM GMT
NerdMaster
For
Life
Your skin, when soaking wet, has about 200 ohms resistance. That's why people standing in puddles CAN get electrocuted by 115 volts AC. But again, only if it goes through your heart. So use one hand at a time (and wear rubber-soled shoes) and again it's hard to be electrocuted. Getting your hand across 115 volts is not pleasant, though. 220 volts AC hurts worse, as you'd imagine.
Bottom line, don't do this. Use a voltmeter to insure the circuit is dead before you change any wiring. As others have said, it's usually very difficult to get ANY level of shock off a BOE board -- a 6 volt battery circuit just doesn't have enough voltage. So for this to happen sounds like a serious grounding flaw, which had to come from your RS-232 connection to your computer.
Put a voltmeter from the frame of your computer to a good ground, and see that it's at zero volts. If it isn't, you may have to replace the power supply of your computer.
csavage@parallax.com
I·should stop writing code at 1 in the morning.
Post Edited (bob000555) : 8/24/2006 6:42:16 AM GMT
