SX/B compiler question
I have a fair ammount of BS2 experience and am trying to make the move to Move to SX/B. I'm still working on getting familiar with the debugger and complier. When I edit my program, Blink Runs.sxb· the compiler barks thet there is an error JMP @start.· I didn't put it there.·and when I delete it the program will compile and run.·My questions·is this, why does the complier insert the JMP @start comand(?) apparently everytime·I edit the code?
Thanks.
Thanks.
· The "PROGRAM Start" line tells the compiler that the program will begin at the label called "Start:". But you don't have a label called "Start:". That is why you are getting an error.
· Simply put a label "Start:" before the first instruction. Or in your example change "PROGRAM Start" to "PROGRAM LED".
Bean.
Cheap 4-digit LED display with driver IC·www.hc4led.com
"You're braver than you believe, stronger than you seem, and smarter than you think" Christopher Robin to Pooh
My apologies for not spending more time in the HELP files.
Post Edited (Philip Gamblin) : 8/18/2006 5:45:06 AM GMT
