Two EEPROMs on the same IO pins
I got my new chips today (see C64 ROM Loader topic for more info)... I hooked them up to my breadboard and was wondering if there was something special I had to do to address the two chips individually.· I tied both chips' SDA and SCL lines to pins 5 and 6 (so they share the same I/O lines).· I pulled-up pin 0 (address line 0) on one of the chips, thinking that would give it a unique address.
To test this, I formatted each memory location with $00, to give it a known state.· Then, I wrote $AA into location $7FFF, $AB to $8000, $AC to $8001, and $EF to $FFFF.· When reading back all memory locations, $AA comes back in $7FFF, $BFFF, and $FFFF - no other memory addresses have non-zero values.
I also verified that each EEPROM works when hooked up individually by writing to and reading from each address from $0000 to $7FFF.· It's just when they are tied together is when I have problems.
Have a look at my attached sample program, paying close attention to the ReadByte and WriteByte routines.· Any ideas on why it doesn't work right?
Goog
Doing my part to keep the Commodore 64 alive!
http://www.commodorestuff.com
Goog
I almost hate to ask, but do you get $AA at $3FFF as well? What's the part number of your EEPROM? Also, try this:
··EEPROM_Addr1 = %1010_0010
The last bit is the R/W bit, not an address bit. A0 is in bit 1.
No, I was not getting any other values - just the ones I listed. But it doesn't matter now because it seems to work now that I got the address bits in the right place! [noparse]:D[/noparse]
Thanks - you are a great help!!!
Goog
http://www.ramtron.com/doc/Products/Nonvolatile/Detail.asp?ID=41&gr=5
Spec sheet here:
http://www.ramtron.com/lib/literature/datasheets/FM24C256ds_r3.1.pdf
Goog
Again with the good news!
james
